Question about Logitech Driving Force Pro Steering Wheel for PlayStation 2
Groaning noise in the steering
2004 silverado. steering when turning to the left makes a groaning noise.
  • 23 Answers
It may be your powersteering pump.
Posted on May 24, 2009
My car makes a low pitch groaning noise when i make a left turn does my power steering fluid need to be changed it is dark brown and there are no leaks
a change will not hurt it
If the noise is only from one direction it could be suspension related or box related . have an accredited steering specialist shop look at it.
Mar 14, 2015 | 2001 Saturn L-Series
Hi. I own a 2004 Buick Rendezvous and I must say, it's the best car I've ever owned. Recently, like within the last 2 months I've had a groaning noise with every left turn. My husband filled...
he filled the PS fluid? it was low? If so it has a leak somewhere, usually the high pressure line. the rattle could be anything, have the front end and steering linkage checked. tie rods, sway bar links, ect.
Aug 03, 2011 | 2004 Buick Rendezvous
It makes a groaning noise when I turn the steering wheel left or right
Hi! You may have a power steering issue. Please check the power steering fluid level if its sitting on the Max or Hi level. IF its not, then you may need to re fill it to get rid of the annoying noise. Plus, running on an almost empty power steering fluid may damage the steering pinion. Hope this helps and have a good one!
Apr 05, 2010 | 2006 Lincoln Zephyr
Car groans when turning corners
You need to describe the problem better. Does it groan only when moving and turning, or will it make the same noise just sitting there turning the steering wheel. If it only makes noise when moving, that rules out a ps problem, the ps doesnt know if you are moving or not. Does it make different noise if you are going to the right or left, same noise, different? I dont know about the reservoir, some of them have filters, but I dont know if Buick does or not. If it was, it would cause a whine, not a groan.
Dec 19, 2009 | 1999 Buick Park Avenue
2004 chev silverado ext cab. No Power steering
Hi Hollings,
You description was very good, I need to ask for a specific.
When you turn to the left, the wheel is stiff like the engine is off or does it turn smoothly but the vehicle doesn't turn or seem to respond.
I'm trying to rule out broken mounts,
Also, if the wheel is all the way to the right, is it difficult turning back to the left the whole way, or half way. See where I'm going.?
Please comment back your findings
Best regards
Mike
Sep 07, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Rubbing or grinding noise in steering wheel
Hi, this could be a combination of many issues. i would check the following.
Check the strut mounts. there could be some damage here concerning the mounts. i would also check the control arm bushings as well. check for damage here. I would also inspect the CCV half Shaft as well. this is a known problem spot(re manufactured)CCT.
The last problem spot here will be the actual wheel bearings in the front. they may be worn or dry. this could cause the symptoms you stated as well.
you will find the issue in one or all of the above problem spots stated.
Please rate and god bless:)
Apr 27, 2009 | 2004 Chevrolet Silverado
Loud groaning noise while turning left
Hi
The groaning noise is the power steer pump operating under duress. I would suggest having the front suspension checked for any seized or failing ball joints or control arm problems. Most suspension guys will give the undercarriage a look over for you for free to check for any failing/unsafe parts. The engine belt driving the power steer pump should also be checked in case it needs adjustment.
regards
robotek
Dec 06, 2008 | 2002 Buick Regal
2004 audi a6 3.0l noisy powerstearing
check for leak in power steering hose by taking cap off the power steering resevoir and than starting car, wait 1 min, turn wheel all the way left and than all the way right. do this about 5-8 times slowly over 3 min or so. turn car off, than observe fluid in resevoir. if you see lots of bubbles after 30 seconds or so, you have a leaky hose. air in the system makes the steering pump groan and moan and vibrate. if the pump is not bad, than change the hose and clamp. just fixed mine yesterday.  also buy a quart of 11s pentosin power steering fluid (green)...
Nov 21, 2008 | 2004 Audi A6
Suspension groans when making a left turn
sometimes the noise is in the steering wheel the plastic is rubbing together causing that sound.
Jul 15, 2008 | 2000 Ford Taurus
Logitech Driving Force Pro Steering Wheel for PlayStation 2 Logo
467 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
