Question about Newco RC-2 Coffee Maker
RD 3 coffee maker does not brew
I have a Newco Vaculaor model RD 3. I can hear the water boiling but nothing but steam ever comes out. I get a few drops of water in the carafe and that's it
  • David Shaub May 11, 2010
    Make sure everything is TIGHT. Just replacing things loosly to make it easier next time, will prevent getting enough pressure to push the water through.
4 Suggested Answers
  • 10865 Answers
SOURCE: I have a Newco Coffee
Hello. Here is a free link to the owner manual in the pdf format http://www.retrevo.com/s/Newco-NKLP3AF-Coffee-Makers-review-manual/id/3879ag209/t/1-2/
Just download it to see exactly what you have. J.
Posted on Sep 14, 2010
EsWorld
  • 1618 Answers
SOURCE: My newco direct water fed
You are right on it is the solenoid, there might be something keeping it from closing properly.
Posted on Jun 14, 2011
mc1bean
  • 3053 Answers
SOURCE: my office coffee maker is
Hello, jb
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
My Curtis Gem-12 is boiling the water before it even brews
Check water level sensor for lime deposit and clean with vinegar. Otherwise that is what it should do.
Dec 16, 2016 | Curtis Coffee Makers & Espresso Machines
Adjusting water flow Newco coffee machine
replacements parts for NKL3AF:
front switches for upper front & rear not plates and for the brew start/ready green lamp
Can I download the users manual/guide too?
thanks
Manuel Florez
(787)609-4115bsat4ube4gblqiaaaaasuvork5cyii=
Feb 17, 2014 | Newco Coffee Makers & Espresso Machines
I just purchased a Bialetti stainless steel 6-cup stove top espresso maker. I cleaned it, assembled it according to the instructions, and went to brew my first coffee. I didn't grind the coffee too fine,...
There is a valve in the compartment where you place your fresh, cold water. This valve must not be covered as it is necessary in building up steam pressure to push the brewed espresso upwards. Also, most stove espresso makers have a rubber type gasket that is usually placed on the base of the upper part of the maker. Check that you have a gasket.
Apr 19, 2011 | Bialetti 4cup Stainless Steel Espresso...
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
The water is boiling, but wont flow into the filter??
Remove sprayhead and pour water into tank until it flows from the brew tube, then replace sprayhead and brew coffee.
Mar 14, 2010 | Bunn VPS Coffee Maker
My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Jun 23, 2009 | Mr. Coffee TFTX85 Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
NEWCO manufactured 1989 model RC-28F
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Aug 28, 2008 | Coffee Makers & Espresso Machines
Sissling when making espresso
First of all, do you steam your milk first then immediately brew the shot? If so, that is your problem. When you depress the steam switch, the temperature elevates way past what is optimal for brewing espresso. If you try to brew immediately after steaming milk or using the hot water feature, that would definitely be why your espresso sizzles. Your shot will likely come out burnt tasting, thin and just plain rancid.
Either brew your shot first (learn temperature surfing for your best shots), or immediately after steaming milk, turn off the steam switch, depress the brew switch (without portafilter in place) for a few seconds until no steam comes out- only water (wait till you don't hear the sizzling sound). Hope this helps.
Aug 07, 2008 | Rancilio Silvia Espresso Machine
Newco RC-2 Coffee Maker Logo
43 people viewed this question
Top Newco Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Newco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
