Question about Proscan PS32700 32" TV
Remote malfunstioning tv not setting up manually
Remote not working cannot set up tv manually
  • Proscan Master
  • 3,866 Answers
You can do this go to www.remotes.com and order the same remote that your manufacture puts out for your tv. Granted it will take a few days to get to you. Some universal remotes will not get you to the setup screen so do not risk you money on them.
Thanks
Rulds2008
Posted on May 23, 2009
How can I switch channel from Ant. Over to TV with no remote on a 2006 Sansai tv set
Every TV has buttons that can do all a remote does, check the user manual or google the make and model. user manual for instructions,
Nov 10, 2016 | Televison & Video
Where is "set" button on the remote so I can set DVD code?
You need to be using the TV's remote, not the Time Warner remote.  You are reading the TV's manual to set it's remote, not the Time Warner remote.  If you want the Time Warner remote to operate the TV, you will need to find the instructions that the Time Warner box/receiver provides and enter the TV's code.
Mar 24, 2009 | Toshiba 36A50 36" TV
How do I set the clock on a fisher fvh-7600 vcr I do not have a owners manual
Also having no manual for a Fisher FVH-7600, I eventually guessed how to set the clock after finding a remote control (Fisher RVR-7600) that works with it.
With the TV and VCR connected and powered on, the TV set to channel 3, and the remote's FUNCTION switch and VCR/TV button both set to VCR, I see a blank blue TV screen.
Then I press the PROG. button on the remote, and a menu with instructions appears on the TV screen. CLOCK SETTING is item 1 on that menu.
Sep 23, 2014 | Televison & Video
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
Tv remote doesnt work
Consult the owner manual carefully as the set may have a way to lock out or not allow the remote to work.
Yes, it could be the remote receiver in the set is bad but if you just bought the set--it should have a warranty.
It is either the remote is locked out or bad or a issue in the set.
Apr 08, 2012 | Televison & Video
I receieved a SYLVANIA 6432GG TV with a remote. The remote control doesn't work. The previous owner had programmed a Comcast remote control to use on the TV. I don't know how to reprogram t
GOOGLE THE MODEL NUMBER OF THE SET (IF ORIGINAL REMOTE) WITH "manual" which would get the owner manual to do this.
Each set is different in this process.
Apr 08, 2012 | Sylvania 6432GG 32" TV
Cable remote AND vizio tv remote will not turn on the tv
We will presume you do not have two bad remotes---the fact you can operate the set manually with the buttons there suggests a problem with the remote receiver====there is a tiny infrared receiver in the front of the set that receives the signals from the remote and sends them inside the set where the correct action is taken.
Make sure if you see it (usually small black area on frame of set) it is not blocked or dirty.
Failing that you may have a bad receiver for the remote---shop repair.
Mar 15, 2012 | Vizio L32 32 in. LCD HDTV
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Sep 15, 2011 | Sanyo AVM-3259S TV
Televison & Video Logo
61 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
