Question about Maytag DWU9962 Dishwasher
Won't drain I'm helping my daughter long distance,their dishwasher won't drain. I had her remove the course strainer to check the well for debris. She said she cannot get in it because the sprayer is in the way. How is the sprayer removed to access the drain well in the Maytag DWU dish washer?
  • danstabile May 23, 2009
    Thank you, you had it right.
    Found the problem, it was a new disposal, they forgot to pop the plug.
    However, in the process, she dropped one of the strain mounting screws into the well. So now we have to get that out before putting it back together. How is that washer arm removed? She's looking for a magnet (but those screws are likely aluminum or stainless anyway).
    Any help appreciated!
    Dan
  • steve
    steve May 11, 2010
    Remove the drain line from under the sink. Place it in a bucket. Set the DW for drain and try it. Let me know what happens.
  • 20 Answers
In most cases the blockage is at the end of the drainhose, where it connects th the "peatrap", simply removing the hose clamp, then hose and inspecting. If no blockage found there you will need assistance. If you want, you can funnel your hand over the end of the hose, blowing down hard through this funnel can sometimes dislodge blockage. ALWAYS rinse dishes before loading any dishwasher.
Posted on May 23, 2009
  • granttaylor2 May 23, 2009
    These screws are stainless. Try using blutak (prestik) on the end of a screwdriver or similar.
    Not familiar with Maytag, but all dw"s I have experience with simply pull in an upward direction. The upper sprayarm usually needs a quarter clockwise (looking from bottom up) turn at the centre collet, or lifting on a tab close to centre point.
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My Miele dishwasher has the red drain light on and won't drain
most common, debris stuck in the drain pump. remove the triple filter, remove the non return valve. clear the debris from the drain pump impeller. try to drain again. also make sure you dont have an obstruction in the drain line. if you replaced your garbage disposal recently, make sure they knocked out the drain plug when they connected the dishwasher. also make sure your dishwasher drain line connects directly to the disposal, and does not run to a air gap in your countertop. miele dishwashers will not function properly when connected to an air gap.
Mar 23, 2012 | Miele Dishwashers
Kenmore ultra won't drain completely
Have you checked the food collector vent? With mine I had similar problem,when i removed the debris from the vent,and then ran the empty dishwasher for a full cycle it cleared up the not draining problem.
Sep 17, 2011 | Dishwashers
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 23, 2011 | Dishwashers
It won't drain
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jun 13, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher doesn't drain completely after the wash & dry cycle is complete Kenmore dishwasher
Hello- A clog in drain hose or debris in sump strainer is most likely cause. Strainer may be accessed by removing accumulator cover. Clean out debris and should drain fine. Let me know if this info helps- have more if needed. Thanks- Ed
Mar 11, 2010 | Kenmore Dishwashers
KitchenAid KUDP02CRBL3 won't empty
u can chk the air gap which is mounted on the rhs rear corner of the kitchen sink.remover cover of the air gap and look for any stuck food debris there.stuck debris can restrict the free flow of water during the drain cycle.machine has only 2 min fixed drain cycle and therefore some water could remain in the the unit at the end of cycle.
Aug 17, 2009 | Dishwashers
Not draining water
The most common problem is that there is a chunk of debris stuck in the small pump that feeds waste water into the rubber hose drain line. Remove the lower front panel on the dishwasher to get to the drain pump. Take it all apart and take a look. Remove the debris and reassemble everytning
Apr 30, 2009 | Dishwashers
FDW60 Dishwasher
HI
The strainer is located directly under the lower sprayer arm. When the strainer becomes clogged with food and detergent debris, the dishwasher may flood or overfill. On some dishwashers, the strainer is a plastic or metal component consisting of two semicircular halves. To remove this type of strainer, pry it up. On other dishwashers, the strainer is a one-piece component. To remove this type, remove the cap that holds the sprayer arm on its shaft. Then remove the sprayer arm and the strainer.
Wash the strainer in the kitchen sink with water and a mild household detergent. Use a fairly stiff brush to get all the debris out of the holes and slots in the strainer. Rinse the strainer well and replace it. If part of the strainer lifts out for regular cleaning, check it and clean it -- if necessary -- after each load of dishes is washed.
Oct 13, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
241 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
