Question about Yamaha RX-V663 Receiver
Will not start up, no response after three attempts.
A few days ago the I would turn the receiver on, there was a lot of static in the audio and when I would turn the volume up or down there would be a small popping sound. If I would restart the receiver the problem would usually be resolved. Last night the problem persisted and the usual remedy did not fix the problem. Now this morning the receiver would not turn on. The display would say "Main On" and then it would power down. After three attempts the receiver becomes unresponsive.
  • 6,784 Answers
HI, theses popping sounds were capacitors exploding among other components as well. this is usually caused by a malfunctioning power board that has allowing way to much current in. the main has been fried in this case.
remove the cover and look for a fuse by the power cord solder(connection) point. if there is no fuse in the section, this will confirm major burn out.
Replace the entire main and power Assembly in this case.
Posted on May 22, 2009
Is the volume control easy to repair and are needed parts available?
If it is a potentiometer that controls the volume and you have some experience and a few tools you will almost certainly be able to find a replacement in one of the many constructor catalogues and be able to change it.
Modern electronics tend to just use buttons to turn the volume up or down and those have been with us for longer than we realise. In the early days of this technology the manufacturers wanted to use buttons but the buyers still wanted a nice big volume knob so there was a compromise where behind the big knob is a mechanism that presses buttons as it is turned.
I suggest you take the amp apart and take a look at which method is used. I have managed several years ago to repair such a mechanism by making a replacement pert from a piece of junk plastic.
Jan 03, 2016 | Audio Players & Recorders
I bought a Denon AVR 791 receiver two months ago, work great, sound great with my Definitive Technology Speakers but 3 days ago while I was watching a movie on my PS3 the receiver turned off on the higher...
Clearly, it thinks you're overdriving it.
Blinking Power Indicator every 2 seconds means the internal temperature is high. (Page 76 of the manual)
Every half-second - speaker impedance too low.
Consider the load presented by the speakers and what their minimum impedance might be.
Check for loose speaker wires.
Feb 07, 2011 | Denon Audio Players & Recorders
I need replacement volume control knob for GoldSstar stereo. It's over 10 years old.
check ebay there is a lot of people that sell knobs and such for older receivers for this very reason. older units that have failed and they strip it down etc. I'm not sure on your receiver but have seen many used knob sets the last few days for various systems.
Jan 06, 2011 | Audio Players & Recorders
Denon avr-3200
Check a few things first to narrow this down a bit. Disable the surround processing. If this clears up that channel, then the problem is in the processing area. If the static remains, vary the volume. Does the static change volume too? If so, then the problem is in the beginning stages of the pre-amp section and is likely a transistor or two breaking down. The parts for this would be in the $5 range. This would probably be considered a "major' repair becaue of the time required to hunt down the defective part.
Dan
Mar 28, 2010 | Denon AVR-3200 Receiver
My receiver is making a static through my speakers even when the volume is turned all the way down
Check the electric outlet to make sure the polarity isn't reversed, which can cause static. Also, check the outlets in the room to make sure they are all grounded which can also produce static. Also, certain cell phones operating a different frequencies can produce a static.
Feb 25, 2010 | Denon DRA-275R
Get a lot of static when try and turn volume down low.....in fact, sometimes it is hard to get sound when you turn the volume down....it is either full blast or silent.....lots of static like noise when...
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
Dec 03, 2009 | Tivoli Kloss Model One AM/FM Radio
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
No sound at all
I suggest if your handy , to open the receiver and look for a circuit breaker or a fuse that protects unit of being damage , replace it and turn it on , hopefully it will work .
Apr 18, 2008 | Yamaha HTR-6030 Receiver
Yamaha RX-V663 Receiver Logo
138 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
