Question about Whirlpool GEW9250 Electric Dryer
Bought dryer preowned and it didnt come with a power cord
I dont know where the green wire gets connected. Can you send a diagram?
  • 2 more comments
  • money_saavy May 23, 2009
    There's already a green striped wire coming from the hornace connected there. Do I connect along with that wire?
    This is a 4 wire connection in the rear of the dryer, red , white, black and green.
    Thanks, That did it!
  • Dan Todd May 11, 2010
    Is it a 3 wire cord or 4? Are you talking about where the wire connects to the dryer in the back or is it a house wire to an outlet?
    President:
  • 1,136 Answers
Hi, if you are talking about the green ground wire on a four prong cord, the green wire goes on the ground screw located on the cabinet next to the power block cover. I hope this help you.
If I can assist you further, please let me know and please rate my response so that others as well as myself can se how I am doing.
Thanks
Vic
Posted on May 23, 2009
  • 1 more comment
  • Victor
    Victor May 23, 2009
    Yes. It is just an extra ground wire.
  • Victor
    Victor May 23, 2009
    Yes, the red and black wires go to the outside post and the white goes to the middle ground. The green is suppose to connect to the cabinet just outside the block cover. Is there a 5/16" screw next to the cover?
  • Victor
    Victor May 23, 2009
    You're very welcome!!
Bought a whirlpool dryer used and the power cord isnt connected how do i know how to connect it
Hello
Here ya gooldtech2332.jpgoldtech2332_0.jpg 3 wire cord center to center outside to outside 4 wire red to red white to white black to black and green onto the cabinet
Aug 13, 2011 | Whirlpool Dryers
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Same dryer but I need to switch to a 4 prong cord.Please help!
WARNING! I believe you want to replace a 110V-120V plug with a 220V. Don't do it until you know for sure. Sounds dangerous! Not an expert, just some free advice from a novice.
I need to change my eltric cor from a four wire to
The following link explains how to install a power cord for your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Refer to the section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, let me know. I hope this helps you.
PS The GREEN wire is ground and gets grounded to the appliance frame.
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
Hooking up the four prong cord to the dryer
this is the rule of thumb,white always goes on the middle terminal ,the 2 outside terminal wires it does not matter which side they are on,if you can see the red and black wire on the terminal block then match them up,the green wire gets mounted to the cabinet,you should already have a green wire to the cabinet so remove the screw and put both wires there and your done,let me know how you do-mike
Oct 15, 2008 | Frigidaire FEQ332E Electric Dryer
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
How to hook up all four
code says disconnect green wire from dryer and tape off and put green wire from new cord in its place green wire from dryer actually connects right back to white wire
Aug 05, 2008 | Dryers
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
89 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
