Ihave a 2wire gateway and a 2wire wireless,i am trying to do port forwarding on the wireless and and i cant seem to get it done how do i do this.iput the info in about the app and the port number and
  •  C. Dante
    C. Dante May 11, 2010
    Please provide more detailed information on:
    1. Which Router model are you using?
    2. Which application do you want to forward?
  • Richard Eisenstein May 11, 2010
    What brand router do you have?
    President:
  • 688 Answers
Are they both router?
if they are both routers chances are they are both trying to do the same thing.
give the make and model and we will see whats up
Posted on May 25, 2009
3600hgv lost password
-How to Change the Settings on a 2Wire Router
Instructions
    • 1
      Open your "Start" menu and go to the "All Programs" section. Open the Command Prompt program in your "Accessories" menu.
    • 2
      Type "ipconfig" in the Command Prompt and press the "Enter" key. Make note of the default gateway address that is displayed here.
    • 3
      Open Internet Explorer and type the default gateway in the address bar to load the 2Wire router's interface.
    • 4
      Click on the "System Password" link if you do not know your password for the 2Wire router. You will be asked to reset it with the system key printed on the router. Or call 2Wire support to get a temporary password.
    • 5
      Navigate to the "Broadband Link" icon to edit the authentication settings used to connect to the Internet. Use the "Home Network" icon to get to the wireless settings. Click on the "Firewall" icon for settings such as port forwarding.
Dec 14, 2011 | 2wire Computers & Internet
How do I forward a port on my 2wire970 router.
The sad answer is that you really can't forward a port on 2wire equipment. Since the hardware is provided by the ISP they only give you basic settings (security keys, firewall etc). There are advance features you can hack into (http://www.mydigitallife.info/2007/04/29/advanced-configuration-page-for-2wire-homeportal-residential-router-gateways-singtel-mio/) but I wouldn't recommend it. If you do the advanced settings and mess anything up they may charge you for the router or cancel your service. The easiest solution is to get a personal router that supports port forwarding and just connect it to the 2wire router you already have or just replace it with the ISP (if it's a wireless router) for a normal box.
Apr 03, 2011 | 2wire (1000-400108-001) Router
Portforwarding: Incoming connections on port 80 not possible
try using DMZ plus mode to open all ports to be accessible for that particular application, or specify the application name with the corresponding port on the 2wire modems firewall settings
Nov 22, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Fix this thing before my 20 oz estwing does......
Below are some links you can check out and see if it would help you make the gaming console connect to the net behind a 2wire adsl gateway.
Nintendo Wii behind a firewall/router:
Port Forwarding on a 2wire gateway:
Nov 06, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Trying to use port forwarding
hi!
i tried to remote access your modem using the serial nos. but it didn't give me anything, pls try to run system setup wizard from your computer by accessing gateway.2wire.net or homeportal/setup, once you have configured the modem with your own settings, please let me know and i'll try to open some ports for you
Mar 23, 2008 | 2wire HomePortal 1100 Router...
I have a 2wire 2701HG-B
gateway.2wire.net... try that, it should work
Dec 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Port forwarding? 2wire 2701hg-T
try the link below it may do it for you if your router is supported on the site http://www.portforward.com/
Sep 04, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
