Question about Logitech USB Desktop Microphone
How to connect the two wires plugs pinc and green pluggs
Hallo! There is not any problem with my microphone.my microphone is brand new ,the one which is with "Changing Color Plates" There are two wires with two different plugges to be connected to the computer , one plug is pinc color and the other one is green color I know that the pinc one is for the microphone but I dont know where is the place of the green plug on the computer .The reason that I bought this Mic. is for two purposes:- 1- To listen privately in my head phone, or 2- to listen without head phone when I need to ie. my family to listen. My question is kinly help me how and where shall I connect the green wire thank you in advance. Edward
    President:
  • 1,138 Answers
On my computer (Compaq Presario) the green jack is the headphones out. I hope this matches yours.
Posted on May 23, 2009
My Headphones are brand new, I plugged both jack's In, and Their Is no sound. Am I doing something wrong?
plug in green plug into headphone and pink into microphone. Check speaker / sound settings on p.c if its a p.c. you are plugging it into. Check not set on mute and check levels .
May 14, 2015 | Audio Players & Recorders
How to connect a plug electric dryer to a 4 plug outlet
for short, just dont mind the color.. the black wire from the new plug goes to right in/on the appliance terminal block, the white from the new plug goes to both white in the middle of the same terminal block and the red wire from the new plug goes to left terminal block of the appliance therminal block and of coarse the green from the new plug goes to the appliance frame.. no need nor sense in trying to figure the wire color of the appliance as it does not mean anything really and it does not follow any rules nor standards..
Nov 08, 2014 | Dryers
How do i hook up speakers? the light on the speaker is green and when i plug them in i get some pop up asking what device i plugges in.. in and out, line, mic, headphones.. help
you will need to connect your speakers to your computer then you will need to install them to your computer
usually at the back of a desktop computer there is three input plugs blue green pink/red or a usb connection depending on your speakers on a laptop usually a usb connection
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your hardware in XP in W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or you might have to boost
hope this helps you
Aug 30, 2011 | Acer (90.18612.36B) Computer Speakers
Wiring broke for all five wires in the usb connection of a Rosetta Stone Head Set 20090205. I may be able to re-attach. Where do the wires go on the usb plug?
Open the plug case by prying it apart.
The tiny circuit board is labelled on one side - three connectors for the headset and two for the microphone.
G - headset ground - red/gold wire
R - headset right - blue wire
L - heasdet left - red wire
M+ - microphone + - green wire
M- - microphone - gold wire.
Use hot soldering iron to 'melt' off the tip of the wire coating and apply tiny amount of solder. Place wire in position and solder together.
Finally use electircal tape to hold the plug covers together and continue to tape along the cable so it will not pull out again.
Jan 17, 2010 | Rosetta Stone Spanish Level 1-2-3 Full...
Brand new wired usb logitech rock band microphone not connecting to x360
The microphone is only compatible guitar hero, not rock band. Thanks and have a nice day J -
Dec 25, 2009 | Logitech (6775091) Microphone
I replaced the high voltage flyback transformer (FUJ-34002F), and I'm also installing a new FUJ-29002C, and did not mark which connectors connect to what wires. Can you please provide me with the wiring...
The good news is with exception for the yoke plugs and convergence plugs, they all will be a diffrent shape and size so it will be difficult to get them in wrong. Just don't force a plug on if it does not fit. If your board has yoke plugs they usaly will be marked with a red green or blue mark on them, this is also true for the convergence pluggs, and the board is usaly marked with the same color.
Oct 10, 2009 | Samsung Televison & Video
Lost manual for hp compact.
The speakers wires are normally color coded if the computer isn't ancient, the Speaker PLUG is green, if you are using the speakers in the monitor, then plug the green one from monitor to green jack on back of PC, (Microphone plug and jack is pink/Red).
If you are using other speakers 3rd party, 4.1,5.1, the hookup is different usually, But I think you need green to green, there should only be one green plug on back of PC, It may be labled sound out. but yours is probably green.
PS you also need to kake sure the monitor speakers dont require their own Power Supply/ AC adapter, Most of them do, while some desktop and monitor speakers do not just connect the cord ffrom monitor to green jack, "sound out". If this helps, thanks for the feedback
Mar 31, 2009 | HP Pavilion F1703 17" LCD Monitor
Speakers wont work
Can you tell me what brand they are?
I can try to help without the brand name:
Go to start and hit control panel. Next click Sounds, Speech, and Audio devices. Click 'change speaker settings'. Click audio in the tabs. Click the droplist and select the speaker brand you have.
If that doesn't work, make sure the speakers are connected to the correct computer jacks. Green is the common speaker color, so hook the speaker wire into the green computer input.
Pink is microphone, so that could be the problem.
Hope I helped!
Jan 23, 2009 | Dell A215 Computer Speakers
Rock band microphone for ps3
plug everything in and make sure one of the remotes are on and then press x when the remote is on....that should solve your problem
1. plugg wireless guitar in
2. plugg drums and microphone in to the extension
3.make sure one of the controllers is on the press x
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Logitech USB Desktop Microphone Logo
186 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
