Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
Zenith P42W34 EDTV Plasma Black Line
Black Vertical Line (2-3" wide) runs top to bottom. I saw an earlier suggestion to check filter cap. And the offer to send that person PDF of the Service Manual. Might I get that PDF?
Thanks
  • 6 more comments
  • frustrated10 Nov 07, 2007
    I have a 42 inch Sanyo and have the same 2-4 inch black bar running top to bottom. Since it is hanging on the wall and heavy it is not easy taking it down to get it serviced.
  • hp trouble Nov 30, 2007
    I have the same problem, I have a HP 50" and it is hanging on the wall as well, I bought it october 16th 2006 with a one year warranty and of course exactly one week after the warranty went out a thick black line appeared. I contacted BEst Buy and they would not stand behind it. They put me in contact with a serive tech. that is supose to come out to my house on monday. I was kind of hoping to fix the problem before then so that they would not have to come out and me give them 100.00 just for stepping foor in my house.
  • Anonymous Dec 31, 2007
    I called Zenith and stated that the black vertical line seems to be a common problem they stated they had no history on the matter. So if all you guys call in we might be able to get them to take action of some sort
  • FOUAD35 Mar 09, 2008
    Black Vertical Line (2-3" wide) runs top to bottom. I HAVE ABOUT 25 TV Zenith P42W34 WITH THE SAME PROBLEM ANY SUGSETION ?? PLEASE
  • mpoelker May 12, 2008
    My Zenith P42W34 just got the same black line and I was wondering if there was a solution.
  • Dickiejoe Jun 15, 2008
    Had one black line down middle of screen (vertical) and now another has shown up. Anyone have a solution? Seems like a lot of us have problems but no one has found a solution.
  • Tophmeister Sep 10, 2008
    I've got a p42w34 42 inch plasma screen as well however i have three solid black vertical lines. i have the technical knowhow to fix it i just can't find a service manual! can anyone send me one?
  • Anonymous Oct 03, 2008
    ZENITH P42W34 I HAVE THE SAME PROBLEM I HAVE ABOUT a 1inch and a half vertical black like running thru my plasma tv 42 inch,any sugestion whats wrong?or what part needs to be replaced?just last month i had my power board replaced cost me $400
Just reheat and add soder to fuse connected behing the driver boards.
Posted on Apr 11, 2009
  • aharris894 Apr 11, 2009
    I've bought 3 plasma on Craigslist specifically with this problem. It's an easy fix usaully takes a hour. Over time the connection from the soder on the driver board dries and seperate or loses value due to heat transference. Remove the back locate the driver boards they are rectangle like shaped alumiun slats that run across the bottom of the plasma. Underneath the slats you'll see four square like fuses with the number 100 imprinted. Purchase a sodering iron at Sear for $15 add a touch of soder to the ends of the fuse to re-establish the connection. Repeat process for all driver boards, make sure the unit is unplugged before you proceed. I've learned the hard way by frying the fuse on the driver boards, when a one of these fuses burns the number 100 imprinted on the fuse will be chared and discolored. If it's fried replacing it is not a problem just resoder the new fuse to both ends to establish the rely.
    aharris@usa.com
  • gogreen1444 Aug 07, 2010
    Where can you buy fuses that have the number 100 imprinted on it? Do you resoder the old fuse on top of the other?
Black vertical lines on your P42W34? Apply pressure between the silver metal board and the orange ribbon cable on the bottom portion of the TV where the black lines occur. See pic below.
If this helped you, please donate the money you would have paid for the repair to your favorite charity :-)
Posted on May 20, 2009
  • 579 Answers
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Posted on Dec 31, 2007
Just wanted to let everybody know that my plasma has the same problem but mine works fine for a minute and then it has the black line.. I took mine apart as suggested above.
I took regular wrtting paper used as a shim to make the contact
tighter, so far is working just fine.. I do not know if the paper is safe but I'm allways watching mine screen.
Posted on Mar 11, 2009
"Display Assembly" can be sent tp PTS, Indiana and rebuilt for $87.
Andrews Electronics sells it for $267. + s&h.
Posted on Feb 19, 2008
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
I have 2x2" black vertical lines on my plasma screen. Is this the end of it's life or can they be tuned out? Rod
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable near the black lines. Unplug the ribbon cable and look for black chips on the underside of it, I think they say 100 on them, you need to resolder both ends on each chip. Should fix the black line issue.
Dec 26, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black line going vertical through portion of
Connections on c boards, c board bad or bad panel. Disconnect power supply from sus boards on sides before attemting to disaconnect connectors from c board to flex cables. arc from stored energy on power board will burn cables. reseat the connector closest to the bar . reconnect power supply. Next replace that c board by strip. next replace plasma panel.
Dec 03, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have 3 black stripes on my Zenith 42
Turn off the TV then unplug it. Disconnect the cable connection and clean the terminals. If the stripes still exist, you have a bad TCP (tape carrier package). It is responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. This is not an easy repair. Service of an experienced or a qualified technician is recommended.
Nov 27, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
My Zenith P42W46X 42 inch tv got two black lines vertical lines on the screen the were coming and going away before but they are more stable now.i opened it up and wiggled all the connections arround the...
Oct 08, 2009 | Zenith P42W46X 42 in. Plasma EDTV
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Nov 30, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith p42w34 will not turn on
Before Opening, double check something for me and post a follow up. I have this tv and I believe it has dual power buttons. One main and one secondary. A remote can't turn it on unless the main power button on the bottom left is on.
Please post follow up.
May 13, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
2,333 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
