Question about Nerf Stylus Twin Pack for Nintendo DS Lite
Stylus My stylus won't work when I touch the screen, it freezes?
    Problem Solver:
  • 6 Answers
The touch screen on your NDS Lite is most likely at fault, not the stylus.
You should experience a gradual degrade response from the touch screen.
You can buy the screen for less than $3 shipped online and replace it yourself.
thsquare
Posted on Sep 10, 2009
    Problem Solver:
  • 13 Answers
Calibrate scrren look in manual for ds which will tell you how to do it if you cant find manual log on to nintendo.com and search for ds calibration
Posted on Sep 03, 2009
  • 33 Answers
No, the screen is either locked or your calibration is off, try going to settings using the directional keys and A to test calibration
Posted on Aug 17, 2009
    Problem Solver:
  • 10 Answers
Replace the touch screen and make sure the rubber behind the touch screen is there.
Nintentech-Levi
Posted on Jul 28, 2009
  • 33 Answers
Its not the styles it the ds
Posted on Jul 25, 2009
Stylus pen using on adobe photoshop
If it is a resistive touch screen you can use anything as a stylus. To test if it is resistive touch it with a non conductive material like something made of wood or wear a glove. If it doesn't work then it is a capacitive touch screen and then you just need to buy any capacitive stylus and yes it will work. Photoshop should work fine too.
Jul 04, 2013 | HP Pavilion TX2110US PC Notebook
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
How do I change the sensitivity to the screen so that I can use my longnails & not my finger?
you will not be able to use your fingernail on the hero screen. the touch screen is similar to the iphone (capacitive) and different to most other touch screens that use a stylus (resistive).
your finger is required for the screen to pick up where you touch.
there is a special stylus you can buy that will work, but make sure it is specifically for the iphone. a standard plastic tipped stylus will not work.
Nov 19, 2009 | HTC Hero Smartphone
Screen does not react to the stylus when touching on found object
You could try calibrating the screen. To do this, you must go to the little DS in the center of the screen when you turn the DS on. Then touch the yellow square on the far right. It should give you instructions from that point on. Make sure that your stylus doesn't have a scratch on it! If it has a little nick down the middle, then your screen might not get a clear reading as to what you touched.
Hope it helps~
May 03, 2009 | Nintendo Mystery Case Files: MillionHeir...
Cect phone a8+ freezing
If you are talking about the touch screen not being responsive at all under normal conditions, read on.
First try calibrating it. There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Touchscreen not working
umm.. i didnt see the video, but go on www.youtube.com and just search "how to fix touch screen". there should be videos that tell u how to fix it. i didnt see the video since my DS didnt have that problem..HOPE THIS HELPS!!!!!!!!!!!
Jan 24, 2009 | Nintendo DS Lite Console
The screen freezes just after it says hello
have you used the stylus to touch the screen around the Village to start the game? which part are you **** on exactly?
Jan 07, 2009 | Nintendo Professor Layton & the Curious...
Hanged
I read another entry and you have to hold down the red and green button and click your stylus into the bottom little button beside where you plug your phone in to charge.
It didn't fix my problem though which is similar to yours.
Sep 21, 2008 | HTC Touch P3450 Smartphone
China mobile
have a china made handheld double sim touch-screen phone. The device is Winkoy T6688. The touch screen got damaged and after reseting the device, the following notice appears after turning it on:
"Calibration wizard. You have to calibrate the touch-screen. Click anywhwere on the screen with your stylus to start calibration".
Of course you can´t but there´s no other option because it won´t accept any other input until it´s calibrated apparently. Does anyone know how to bypass this calibration wizard on start up?
Sep 10, 2008 | Nokia 6300 Cellular Phone
Nerf Stylus Twin Pack  for Nintendo DS Lite Logo
134 people viewed this question
Top Nerf Video Game Consoles & Games Experts
James Wishart
Are you a Nerf Video Game Console and Game Expert? Answer questions, earn points and help others
