Question about Sharp LC37D64U 37 in. LCD HDTV
No Digital Audio From Sharp LC-37D64U
I am trying to get digital sound from my Sharp LC-37D64U to my Sony receiver.  Unfortunately I am getting no sound, but I do off the analog output.  I then take the digital line and connect it to a DVD player I have, and I do get sound into my receiver (so I no the optical cable and the receiver are working).  Plug the optical cable into the Digital Audio out on the TV and nothing.  Any ideas?
  • the4barkersa May 25, 2009
    It ended up being a defective TV.  Took the set back to the store, they tested it and could not get it working either.  Ended up getting a Sony KDL-40z4100 instead.  Digital audio out work right away.
    Thanks.
    Mack
  • mike loshbough
    mike loshbough May 11, 2010
    not with out a hdmi cable i have the same tv
    President:
  • 1,077 Answers
Try changing the the Audio Setup in the Digital Setup Menu.
If you have your manual, go to pg 11 and pg 28 for Digital Audio Output. If you need a copy of your manual, here's the link.
http://www.sharpusa.com/products/TypeManuals/0,1083,127,00.html
Page 11 has info on the problem and page 28 to solve it.
If that doesn't work, I would try downloading the latest software to fix is problem. Page 28
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=LC-37D64U&s_func_disp_id=27&x=42&y=11
Posted on May 23, 2009
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
Sharp flat tv lc-32sb24u no audio was watching tv last night and the sound just stopped in the middle of a show. picture is perfect. is it worth to fix.
Sir try to check the cables connection at the back of your tv. and if you are using a digital receiver, try to use a dvd to check if there is a sound. If there is a sound the problem is the digital receiver, feel free to send feed back good day and best regards.
Aug 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Sharp,Aquos, LC-37D64U,Power & Sound, No picture?
try replaced main board
Manufacturer Sharp Part Number DUNTKE373FM03S Description P.W.B.UNIT
Jun 03, 2010 | Sharp LC37D64U 37 in. LCD HDTV
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Aquos LC-37D64U - I've got a Motorola DSR505 satellite receiver with a DVI output. As per the Aquos' manual, I hooked it up with a DVI to HDMI adaptor cable and ran separate stereo RCA from one of the...
You have it hooked up right. I found something on page 26 of your manual. Look at the HDMI setup section. I think that maybe the problem there. It's an audio select option for input 5.
Let me know if it works.
Apr 23, 2009 | Sharp Televison & Video
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Jan 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC37D64U 37 in. LCD HDTV Logo
547 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
