Question about Samsung SyncMaster 400 T 40 in. Flat Panel LCD Monitor
When i turn on the monitor/tv the screen should be a solid blue and now only half the screen is blue and the rest is black like its not on I can also hear a small popping noise comming from the back o
My samsung 40" syncmaster400p when i turn on the monitor instead of a solid blue screen initially I should get is now blinking and only half of the screen is blue while the rest is black..is it worth fixing and or how much to repair? thank you Marcos
Replace c1853 and c1854 in power suply they are boath 1500uf
Posted on Jul 04, 2009
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Thanks..
Feb 03, 2014 | Samsung SyncMaster Computers & Internet
On light flickers instead of being solid blue and monitor will not come on
Power off the computer leave the monitor on then go to the computer power button once computer is off and unplug the cord press and hold the power cord down for 5 seconds you should see a blink of light then plug the computer back in and reboot the machine. If this does not work get another monitor to check the video card borrow one to see if it works with a mock monitor if that does not work then it is your video card that is the issue and not the monitor. Change out the video card. if the mock monitor works fine then your original monitor is broken and will need to be replaced.
Jan 08, 2011 | Samsung SyncMaster 2493HM Monitor
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
May 18, 2010 | Computers & Internet
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Half of the screen is black - Samsung SynchMaster 710N
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Sep 05, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Samsung 460Px monitor turns on but no vidio signal going through. Screen turns from black to a dark blue meaning the unit is powered and I get a solid green light.
I have the same problem, the monitor has power, but i can't even switch sources, the front panel is locked and i can't tell if it responds to the remote because there is no menu or picture of any kind
Apr 24, 2009 | Samsung 460PXn Monitor
Not working with Samsung U600
YOu will have to put the headset in pairing mode by keeping the power button pressed till the light becomes solid blue instead of blinking. Now switch on the blue tooth of your mobile and try pairing,. it should work. passcode will be 0000
Jan 29, 2008 | Samsung WEP200 Headset
Samsung SyncMaster 400 T 40 in. Flat Panel LCD Monitor Logo
366 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
