Question about Pine Technology XFX Mach4 KT400ALH Motherboard
Need drivers for XFX KT400-ALH on floppy disk
Hi
My brother's PC crashed, when he tried switching it on again it didn't recognise the SATA hard drive as the mother board is older. I have the XFX CDs but there is no facility to make a floppy to boot and install the drivers for the hard drive.
I have tried everywhere so hope you can help.
Thanks in advance.
  • 1 more comment
  • intutor May 22, 2009
    mgbrake, thanks, below is the info I got from my nephew who built it. I don't have the PC here as by all accounts I just need teh drivers on floppy.
    rulds2008- I'm on driver guide at the momnet but it's on about flsahing the BIOS which is not what my brother or I have done.
    INFO:
    When you install a fresh copy of windows on a machine with a SATA drive, if it's
    an oldish motherboard (which his is) the windows setup doesn't see the SATA
    drive. To make it see the drive, you have to hit F6 and load some additional
    drivers. The only way you can do that is to have them on a floppy disk. It's the
    only medium you can use to do it.
    To make things worse, some compaines
    sent out the floppy disks with the motherboards, but some didn't. I'm not sure
    about Aidan's but he reckons he doesn't have a floppy. Anyway, the ones that
    didn't usually have a utility on the driver CD (the one you sent me) that allowed
    you to make the floppy yourself on another machine.
    I've had a look
    thorugh this CD and I can't find a utility anywhere that lets you do this, so it
    sounds to me like there was a floppy disk sent with the motherboard that he
    hasn't got. Sometimes this can be remedied by finding the right drivers online,
    but so far I've had no luck at all. The company who make or made his motherboard
    ( XFX KT400-ALH by the way!) don't acknowledge it anymore, and there's nothing
    comes up in google that's worthwhile.
    I'm going to have a sift through
    our floppys and see if I can find one
  • intutor Jun 02, 2009
    Finally my brother has tried the Flash bios driver from 'driverguide' I
    sent on floppy, but he gets an error backing up the current BIOS and
    trying to flashh install the new one (see picture).
    Any advice on this? Thanks
  • mgbrake
    mgbrake May 11, 2010
    So, no onboard SATA, and you are trying to load the drivers for a SATA card? SATAless motherboards require an IDE drive or disc or CD to boot first...
  • 3,866 Answers
Www.driverguide.com would have the drivers for that. Tahnks and please rate
Posted on May 22, 2009
  • Grand Canyon Tech
    Grand Canyon Tech May 23, 2009
    Drviers would be at www.driverguide.com you will be able to download them there.
  • Grand Canyon Tech
    Yes but there is a option to where you can use the sata in IDE mode with does not hurt it a but, you do this on your bios.
How do i get my sata ports on my motherboard to work?
Hi there. I think your board is an early SATA board as it has IDE connectors too. I am not able to access the website you have listed but have had a fair bit of experience with SATA drives on such boards. It might well be that there is an option in your bios to switch between native SATA support and IDEmode. If you can find such a facility in bios then try changing it. You should try the drive on another machine to ensure that it is not defective, if the drive is a new one then try it on a very recent machine.
The issue might that the hard drive is not compatible with your board, some SATA3 drives will not work on older boards. The is true of some SATA2drives. It might just be an incompatibility issue.
Good Luck
Feb 10, 2015 | Computers & Internet
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
My hard drive just crashed on my Sony Vaio VGC-LS30e so I replaced the hard drive with a WD SATA HD and the computer is not recognizing it, neither is BIOS. Any suggestions? I went to put the old HD in as...
A bit of research revealed that the system came with a 250GB SATA drive, and the BIOS should have recognized either drive. Check the cable from the Hard Drive to the Mother Board if possible, including the Power connectors.
Sep 21, 2009 | Sony VAIO VGC-LS30E Desktop PC
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Hard drive
at first you have to check it out, whether your hard drive is related on ide or sata. sata is the new technic used now in the recent years. ide is the old technic that comes with the wide bus cables. but sata is a small red colored cable that transfers data more faster than ide.
after that, you have to check it out the mother board settings for connecting with sata cable. because, the older pc have no more settings for sata. if it is available means, no problem to update your hard drive. or you can just go for external hard drives.
Jul 21, 2008 | Dell Dimension 4600 PC Desktop
Felipe
There are seperate adapters that can act as interfaces between SATA and the ordinary ports of the older mother boards.
These are called SATA to IDE adapters,.
see this link
If you have already bought or have some SATA hard drive and like to attach it to *********** board, then these adapters can come in handy
Apr 11, 2008 | Computers & Internet
Hard driver (seagate)
hi,
is it a sata or ide (pata) drive? does the bios recognise it yet? if it does then you know you have a software problem which could mean you may just need to partition or format the drive.
if the bios can't even see it then you will need to change the jumper settings on the harddrive to make it compatible with your mother board.
good luck
smeags
Jan 07, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Pine Technology XFX Mach4 KT400ALH Motherboard Logo
364 people viewed this question
Top Pine Technology Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Alun Cox
Jerry Umali
Are you a Pine Technology Computer and Internet Expert? Answer questions, earn points and help others
