Question about Hitachi RAS-09UH Air Conditioner
A/c help Installed a new 2.0 ton 13 seer condenser and can not get the contactor to ingauge i have 240 on line side and 240 on load side when i push the pins down and the unit starts, i have 24v at the t-stat going in the contactor but it will not close, and i switched it out and the same thing happens, i checked the transformer and t-stat and all checks out good. why is the contactor not closing when it is calling for it?
  • 1 more comment
  • Erne Oct 22, 2007
    I have the same problem, I have 24v at the contactor going in and nothing happens
  • Erne Oct 23, 2007
    The unit is a 2.0 ton 13 seer Duro-Guard        MGF# DAGA024JA
  • tjiamtheman Nov 15, 2008
    I have duro guard 3 ton 10 seer heat pump ac come on but the heat don't.
  • 4,655 Answers
Do you have 24volts at the contactor when the T-stat. is set to cool or heat if unit is a heat pump? The outside unit must have 24v at the contactor to engage
Posted on Oct 20, 2007
  • 2 more comments
  • John Tripp
    John Tripp Oct 22, 2007
    Erne, Hang on I'm going to look into the wireing digram and try to help you a little more. Get back with me if you need.
  • John Tripp
    Are we sure this is a 2 ton 240v unit? Hitachi RAS-09UH ?
    Specs say it is 9000btu 115v 10SEER Won't be able to help you until we get the right info. I'll be glad to do what I can to get you going.
  • John Tripp
    John Tripp Oct 24, 2007
    Erne I am sorry but the web site above your listing posted the incorrect listing, I'm still trying to get the new info that you sent today. Hang on as I'm multi tasking and trying to get you going too! But at this moment I think the wiring from the thermistat to the inside plit ant then from there to the ouside unit is transversed somewhere. On heat pumps they take up to 6 different wires. depending ont he extra features involve like emergency heat and the extra wires that tell the heat pump to engage. Tell me all the things you changed, like indoor t-stat and I will try to get the wiring print for the Duro-Guard        MGF# DAGA024JA
    I thought I had the print on time today but the PDF on the computer froze and I lost the web page.
  • John Tripp
    OK I think I have the wiring diagram For your AC When you are ready and I am home you can call or I will call you and walk you through this. I'm in SC  ESTime My cell number is 864-812-1887 I  won't answer because I don't have you in my call list. The home number is 864-487-4851 and I get home at 4:30 pm during work days. If you get my answer machine make sure you leave me a clear number I can reach you and a convient time.
     Duro-Guard is listed online as a RUDD but not to worry they are the same thing . My wife is Chinese and I'm southern Irish so please be patient if she should answer. There is no charge for my help, I really want to get you working, John Tripp
Ac won't come on
thermostat, transformer, 24 volts missing at outside unit,contactor,no 240 volts at outside unit. all possible.
Aug 06, 2014 | Kenmore ICP Comfortmaker C4A624GKD 2 Ton...
Purchased Rheem 4 ton 16 seer AC installer just left
Ask your installing company for the AHRI number. If installed with a
matching furnace and coil as listed in the certification then you will get 16 seer rating. If they installed something different than what is listed in the certificate then demand all parts listed or a refund.
Jul 18, 2014 | Rheem 14AJM49A01-RHLLHM4821JA 4 Ton 16...
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
Why won't the compressor run
This can be for a variety of reasons. It ranges from something as simple as no supply power (blown fuse, open breaker, faulty contactor, or run capacitor) or it could be more serious as a grounded or open winding in the compressor motor. My suggestion to any novice and or person without proper tools and knowledge; First check the low voltage (24 volt control voltage) by turning on the "Fan on" switch located on the thermostat to on, not "Auto" The blower fan should come on, indicating there's 120 volt and 24 volt available. Fan doesn't come on is an indication that there's no control power. The next step would be to check for power at the transformer and fuse located in the air handler. There should be 240 volts feeding the transformer, and 24 volts coming out. The control voltage is needed to operate the thermostat (which is the switch that sends the 24 volt signal to the compressor contactor to turn the compressor on/off. This 24 volt also powers other relays and switches in the system. knowing that 24 volt is available also tells you that the problem is most likely in the condensing unit (outside, where the compressor is located). At the condensing unit you should check for 240 volt supply power. Upon finding 240 volt supply power the question now becomes whether or not the thermostat is calling for anything (cool or heat if the unit is a heat pump). There should be 24-30 volt available at the small gauge wires feeding the contactor coil. While having the thermostat set at a temperature lower than the current room temperature (in the cooling mode) the thermostat should send a 24 volt signal to close the compressor contactor and turn it on. The non-metallic end of a screwdriver can be used to depress the moveable part of the contactor. After pushing in the contactor, should the compressor start then you may only need a new contactor. It may just hum because of a faulty run capacitor or grounded or shorted internal motor windings (grounded or shorted windings are usually indicated by tripped circuit breaker and/or blown fuse). It's a good idea to have a good multi-meter and knowledge of use before attempting any repairs or diagnosis on your own. I recommend some basic knowledge of electricity before even thinking about attempting any repairs or diagnosis.
May 08, 2014 | Goodman Manufacturing Goodman GSC130421...
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
Is a goodman gsc139421ac a heatpump
13 seer 3.5 ton unit check inside condensing unit for reversing valve. Also open panel and see if it has a defrost board. It is located above the contactor. Rusty
Jun 04, 2009 | Heating & Cooling
We installed a 4 ton downflow coleman air handler with evap coil Model number 1854s2m we did not change out the outside unit. the outside unit is a 13 year old 3 1/2 ton intertherm condenser the system is...
you have a missmatched system, for it to work try removing the orfice on the high side txv it is not allowing the evaperator coil to fill with refrigerant properly coleman and intertherm dont like each other since they control a large market in the manufactured housing heating and cooling units electricaly connecting the componets together no issue prefromance sometimes is the issue hope this helps
May 06, 2008 | Heating & Cooling
Hitachi RAS-09UH Air Conditioner Logo
462 people viewed this question
Top Hitachi Heating & Cooling Experts
ka4iup
ka4iup
bobalix
richie46
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
