Question about Craftsman Garden
ENGIN STALLSWHEN HOT WILL NOT RESTART
ENGINE STALLE WHEN HOT WILL NOT RESTART
  • 4 Answers
The problem with this machine is a bad ignition coil replace it and your machine will run like new again.
Posted on Jun 12, 2009
My machine behaved just like yours, and as other answered you - it was the ignition coil. How ever, I succeded in repairing it. There are a thin silvered copperstrip going in under the black blob, on the inside of the "core". This is the coils earth connection. I solder an extra wire from that strip and connected it to ground. Thats it, bad ground connection - no need to replace the coil!
If you not used to solder in tight spaces - you better ask someone who has enough experience .
Posted on Jul 14, 2012
    Problem Solver:
  • 11 Answers
There is no solution for this. you might consider looking for another weed trimmer. stihl is a good brand to trust. i do not work there or sell them. but, i do own one.
Posted on May 23, 2009
Can i Frush my engin with Desel
If you're trying to flush the engine due to sludge, a more common and very effective flush is to substitute a quart or two of automatic transmission fluid in place of the same quantity of engine oil. Get the engine up to temperature, then drain again. Repeat as many times as necessary, the, finally drain all the oil, change the oil filter, and install the correct amount and weight of engine oil.
-Rod
Apr 04, 2017 | Cars & Trucks
Using alot of water but engin does not seem hot 2009 dihatsu mira
You could possibly have a cracked cylinder head and the water is being forced through this crack ending up as a fine spray in the cylinder/s. The head gasket may also be faulty.
Pouring cold water into a hot engine can cause this, the engine must be running when hot and when cold water is added.
Oct 22, 2014 | Cars & Trucks
Why do the water and oil mix and the engin run hot?
Cylinder head gasket is most likely bad
Jul 03, 2014 | 1999 Honda Civic
Not turning on when warm.
Bad pickup, tough to replace if in the distributor. Also, pull out the computer, it may be located behind the glove box or under the seat. Unplug it and open it up. Look at the computer chips for one that looks burnt. If so, the pickup may also be bad.
Dec 06, 2013 | 1987 Chevrolet Nova
2001 dodge neon engine jerked and stoped on the road starter turns but notheing possiple problems
It sounds like your timing belt may have broke. Have you ever replaced it? how many miles are on the car?
Dec 14, 2012 | 2001 Dodge Neon
Why
You might have over heated the engin... that also might be why it wony start up
Aug 02, 2012 | 1998 GMC Jimmy
Club cadet riding lawn mower manuals
There is an oil reservoir on top of the diff. 10/40 engine oil or 10/50 if it seems like it is slipping in hot weather.
If there there are no oil leaks, then it should still be full.
It has no effect on the engine.
I would check the ignition switch for dirty contacts if it stops once the key is returned to On from the Start position.
Try disconnecting the electrical connections on the seat and transmission to see if that's the problem.
I always disconnect them anyway. I hate it when I need to get off the machine to move an object and have to restart each time.
Mar 26, 2017 | Garden
The bike starts and runs fine however it has now started cutting out, when I slow right the engin cuts out and the oil light come on. all the eletrics are on but when i try to restart the bike its...
Mine has the same fault. The ignition sensor leaks to earth when it is hot so engine cuts out. I've had two sensors fitted. But They still leak to earth. Trying to get Suzuki to sort, permanently.
Sep 02, 2010 | 2004 Suzuki VL 800 Volusia
Garden Logo
290 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
