Question about Acer Aspire One PC Notebook
Pink color should be blue also flashing screen
Acer aspire one color is distorted. Pink when should be blue. Also having issues with screen flashing.
  • Anonymous Mar 24, 2014
    screen comes on but when it boots up it blank and pink why ?
  • Acer Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 23, 2009
I have some picture distortion - pink fuzzy color where white should be (like on hockey ice). I'm trying to determine if the t-con board is to blame and if I might fix it easily
Hi Bill.
I don't see a specific model for your TV, but have owned a rear projector system before. There is usually a sub-menu where you can do fine alignment of the Red, Green, and Blue projectors to get rid of the pink fringe. There is generally a white crosshair at center screen where you can fine align the three colors to get rid of the fringing, and sometimes an advanced menu where there are crosses all over the screen that you can individually select and fine tune, (tweaking the different optical distortions of the individual projectors to overlap).
If the fringe is a big swath instead of a fine edge, or if a color is totally gone, then you may be talking power amp issues. For fine fringes, the adjustments usually work fine.
Hoping that helps!
D
Dec 18, 2015 | Televison & Video
Color distortion-Sony Bravia Model KLV32EX500
check for a loose connection in the t-con board tried with re seat the cable wire in the t-con board.
Oct 04, 2012 | Televison & Video
Pink screen abd pink lines everywhere
hi there.
for this, kindly check the BIOS mode of your machien first to know if the pink lines will still show there and if it still show then you may wanto contact your acer support to arrange a screen repair or replacment since issues like this are usually cause by dead pixels or display driver problem or display driver updates issues
you may use the given phone number below to contact the acer support if yoru screen shows the pink colors on BIOS so they can arrange a repair or screen replacment 800-816-2237
Feb 21, 2011 | Acer Aspire One Netbook 8.9" Notebook
How are they connected from the computer back pink yellow grey
There is a universal color code for sound card jacks. Green jack: Connect the Speakers or Headphones
Pink Jack: Connect Microphone
Blue Jack: Connect Aux Cable.
Nov 19, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire One /Internet Explorer color appears in negative.
Try updating your DirectX files, can be done from here.
http://download.cnet.com/3001-20_4-10176490.html?spi=308dc021e8db6edb867480b0ab606bb6
Hope this does the trick
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
May 26, 2009 | Acer Aspire One PC Notebook
Screen is bright neon pink!
Did you also replace the power inverter when replacing the screen???
Feb 13, 2009 | Acer Aspire 5610-4648 Notebook
Acer aspire one, the color is flashing and changing on the screen
A dull pink color usually means the backlight is going out. You can test this theory by plugging your laptop into an external monitor. If the picture is fine, you know you have a bad LCD on your hands.
They are medium difficulty to replace, and they're widely available on eBay for $100-$200 (USD).
If you have any questions, please feel free to ask. I'll monitor this thread.
Jan 26, 2009 | Acer Aspire One PC Notebook
Laptop acer aspire 5550: pink screen
This is basically happens with a tft.Please check it with a experienced technicin or u can take to your nearest aser service station for repair or replaced the tft.
Regards
ucp_pru
Aug 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
White turns to pink on acer laptop
I had the same problem but the white color became cyan.
I "solved" the problem hiting the back of the monitor. I think that is a problem of contacts between the signal of the monitor and the pc.
I have an acer 5610z.
Juan Pablo.
Jul 28, 2008 | Acer AL1916B 19" LCD Monitor
My Screen is pink
there must be some problem with the hardware of screen. get it checked from a professional
Jul 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire One  PC Notebook Logo
327 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
