Which jumper is slave on my disc drive?
I got a Maxtor DiamondMax Plus10 160Gb 8Mb Cache ATA133 Hard Disk Drive <9.0ms 7200rpm last xmas but have only just put it in. There are no instructions, so I don't know which jumper I should select for slave. When I installed it, it didn't even register on my computer, but I don't want to experiment in case it all goes wrong. This is my first time trying this sort of thing
  • superdave321 Feb 24, 2008
    I am accually reviving a parts machene and I have the 6.0 gig version and I want to make it a slave drive before I boot it up at all. what jumper should I put it on for the slave option?
  • 4,889 Answers
Greetings my friend...Put it to cable select mode(CS) so that the cable will automatically set your existing HDD as master and the new one as slave!
Posted on Oct 19, 2007
I have a samsung spo8o2n taken out of my old pc....ive built a new pc and want to put all the data..photos etc onto my new pc.i have an external h/d box with 12 volt supply and usb cable connection. the unit lights up but nothing happens.there are no jumper pins in the base of the h/d .do i need them and where do i put them to make this work.i have done the other two hard drive this way with no problem.
Posted on Sep 25, 2008
CAN'T ADD SAMSUNG SP0802N 80GB Hard Drive
Posted on Dec 30, 2007
I need driver for diamondmax 21
Turn the computer off.
Turn the computer on, and press <DEL> to enter BIOS SETUP.
Ensure that the hard-drive is "enabled", and set to 'AHCI'.
Save the BIOS settings.
Reboot, and install Windows.
May 03, 2015 | Seagate 250GB Maxtor DiamondMax Plus 21...
Can't format my hard drive
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart If its an external hard drive or a usb pen drive click start right click on my computer select open you should see your pen drive right click then select format another way is to click start control panel administrive tools computer management disk management right click on your drive select format Hope this helps.
Jan 18, 2013 | Seagate Maxtor 80GB DiamondMax Plus21 SATA...
I AM LOOKING FOR LATEST DRIVER DRIVERS FOR MAXTOR DiamondMax 21 SATA 250GB Hard DRIVE FOR WIN XP-PRO PC
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
http://www.seagate.com/www/en-us/
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
My hd 6y080p0 maxtor shows in device manager but does not show in explorer as a usable drive. I am trying to use this HD as a slave drive.
You will just Change the pata cable as new or fit to HDD tightly and restart the PC.If the problem is same, your HDD parturition has been corrupted unfortunately. so you need to format again from >my computer>manege>disk manager >and format.
If you don't want to loss data dowmnload ontrack boot cd and recover the partition.
http://www.downtr.net/297918-ontrack-easyrecovery-professional-621.html
Regards
Shibuda
Jan 03, 2011 | Maxtor 6Y080P0 80GB Ultra ATA133 7200rpm...
How can i recover bad sectors in my hdd drive using a startup disk?
Boot from the startup disk.
Run 'CHKDSK' with the '/F' (to "fix") option.
Oct 18, 2010 | Seagate 80GB Maxtor DiamondMax Plus20 Hard...
I cant erase the files in my hard disk, if i erased it, it's keep on comimhg back..what will i do?
INFO:
Files are never really erased from a hard drive.
At various stages files are always recoverable.
RECOMENDATION:
To truly erase your hard drive take it out and completely destroy it down to many small parts.
Reformat the hard drive.
Hope this tip helps.
r/
David
Mar 11, 2010 | Seagate 250GB Maxtor DiamondMax Plus 21...
Want put additional hard drive in presario s6020wm is this possiable, also do the rpm speeds have to be the same I have a maxtor diamondmax plus 9 80g that spins at 7200, the one in the computer spins at...
It’s very possible to do and no it doesn't matter that each drive runs at different Rpm speeds.
The difference between a hard disk drive that runs at 5400Rpm and a 7200 Rpm is data transfer speed. The 7200 drive will run faster but the drives cache also plays a big part when transferring data. A drive that runs at 7200Rpm with a 16MB cache will run faster than a drive with 8MB cache. The 7200Rpm drive will run a little hotter than a 5400Rpm drive and use a little less power. Typically you’d want to use the 7200Rpm drive as the primary drive. (With windows installed on it).
The 5400Rpm drive should be used as a storage drive and be connected on the same data cable as a slave drive. How to safely remove data from the 5400 drive. Before you shut down the system, open windows explorer. Click on the C:\ than delete the Boot.ini, AUTOEXEC.BAT, and IO.SYS files. (By doing this the drive will no longer be bootable but all the data will stay intact). Shut down the system. Remove the 5400Rpm drive from the system. Install the 7200Rpm drive. (The new drive is an IDE drive. Set its jumper so it is a Master.) Guide to setting-up an IDE drive; http://freepctech.com/pc/001/installing_ide_devices.shtml
Set the jumper for the 7200 drive as a Master with a slave. (The 5400 drive will be added later).
Once the drive is configured and installed boot the system and enter the bios/CMOS menu. Press the delete key to enter the bios or watch you're screen you may need to press the F1, F2 key or F10 key to enter the bios menu. Instruction on how to move about while in the bios is shown at the bottom of the bios screen. You should see the model numbers of you’re 7200 DiamondMax drive within the main bios menu.
You will also need to set the boot menu / boot order.
Open the Boot menu. A typical boot menu would list as follows:
1st Boot device, Floppy disk drive
2nd Boot device, CD-ROM drive
3rd Boot device, Primary hard disk drive.
4th Boot device, not needed
Compaq does not provide bios settings within their user guide. Before you save and exit the bios, open the CD-ROM drive and load you're windows CD or the restore CD from Compaq. Save and exit the bios. When the system reboots it should start up the windows CD or the restore CD. Follow the on-screen instructions from the restore CD. Once windows is installed update windows. When finished it is now time to add the old 5400Rpm drive. Shut down the system. You will need to change the jumper on the on the 5400Rpm drive. Set the jumper to Slave and insert it into an open bay. Connect the data cable and power cable. Check that all cables are fully connected. Boot you're system. Windows should load. You're 5400Rpm drive will most likely be labeled as letter E. You can change the drive letter order by opening the run window. Click Start and in the run window type in: diskmgmt.msc than click ok. Open Help. Click, help topics. Click on disk management.
Compaq Presario S6020WM Desktop computer web site;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00058482
User Guide for S6020WM
http://h10032.www1.hp.com/ctg/Manual/bpb13287.pdf
Cheers'
Mike
Feb 01, 2010 | Compaq Computers & Internet
My slave hard disk is not showing in my computer
Is it formatted ? Does it have a drive letter associated to it? If not then either format it (right click on My computer -> click Manage -> click Disk Management. Now right click the drive if it is showing there and either create partitions and/or format it if it not already formatted.
If it's already formatted, and you just need to assign a drive letter, then in Disk Management, right click the drive and click Change Drive Letter and Paths and assign an unused drive letter, say Z.
Close Computer Management and open My Computer. The new drive should show up now.
HTH,
Deboo
Jan 05, 2009 | Seagate 250GB Maxtor DiamondMax Plus 21...
How do I make my MAXTOR Hard Drive 7Y250M0 a slave?
A slave drive is defined by removing the jumper (pin sleeve) completely from the drive. Then go into your BIOS and if it doesn't auto-detect as slave, manually change the settings and you'll be good. You shouldn't have to go into your BIOS.
If you can see it as slave in BIOS, but not in Windows that means the drive is not formatted properly and to do so, Right click on My Computer in Windows and goto Manage. It should load the Computer Management window. From there goto Disk Management under Storage in the left side browser. You should see the Hard Drive there, right click on that and format it.
That should do it.
Dec 12, 2008 | Maxtor 7Y250M0 250GB Serial ATA 7200rpm...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Computers & Internet Logo
1,281 people viewed this question
Alun Cox
David Payne
David Payne
