Question about Maytag Neptune MDG5500AW Gas Dryer
Control board non operating
Control board was replaced,limits ok,board lights up but still doesn't work when any button is pushed service tech can't find out why
  • Teddi B May 11, 2010
    Door switch usually. What does it do? What does it not do?
  • 149 Answers
Replaced the termal fuse(white). door switch ok?
Posted on Jun 12, 2009
Lights on console are off and unit won't start.
Hello Brian,
I had a similar problem with my dishwasher sometime ago. My husband tried to fix it following the owner's manual instructions but nothing happened. Tired of trying it I called a technician and they came the same day and fix it! They had to replace the keypad, I don't remember how much it was but I know that it was a fair price, around $150, much less than buying a new one!
I'll give you their contact info just in case it helps you. Good luck!
Appliance Repair Toronto Fix Appliance Repair
Mar 15, 2017 | Kenmore Dishwashers
Why won't my system go to service mode
If youre out at the equipment controller and push the button to switch from auto to service and it doesnt work, it usually means you need a new board. Theres a reset button on the outdoor controller, look to make sure it wasnt pressed and got stuck. If that looks ok, then the board should be replaced, buy an iaqualink instead of your replacement board, it is backwards compatible, meaning all of your existing controllers will still work, but it gives you internet/iphone/android control capability as well.
Jul 24, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Furnace blowing cold air after replacing limit switch
Limit switches are safeties and require a manual reset. They are also a Normally Closed contact. A hi temp. thermostat operates on its own. If you are sure it is a limit, find the red little button and listen for it to click. Sometimes they push pretty hard.
Feb 03, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
My LG Microwave is not working. The STOP/CLEAR button does not work
see the next steps: USE THE commons sense . God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
Aug 01, 2012 | Microwave Ovens
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Intertherm model# FEH-015HA It is no longer blowing heat
High limit safety device is probably tripped, it should reset automatically, also check other safety's for tripped condition, they look like small round device located in a variety locations through out the unit with two wires to each one, some have small push button resets located in the burner compartment area. If all the safety's are reset and check out OK the main control board may need replaced. One of the most common causes of high limit safety device trip is lack of air flow, Dirty filters, evaporator coils, malfunctioning blowers, closed supply air registers etc.
Note: High limit safety switches also go bad after being tripped to many times.
Nov 28, 2011 | Heating & Cooling
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
Axis 9 - Doesn´t work properly. It´s crazy !!!!!
your set needs to clean and service have a tech do the work on your set.good luck
Apr 01, 2009 | Nu Mark AXIS 9
Maytag Neptune MDG5500AW Gas Dryer Logo
108 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
