Question about RCA Thomson Digital Cable Modem (DCM305R)
576 wireless modem
Hi, this 576 modem as you know is configured to AOL. I'm with Pipex on regular broadband. Does resetting the modem really restore factory settings thus enabling install? Will I need a driver for it as theĀ ISP CD is for the 330 USB modem. Basically I've not got a clue. Any help appreciated. Thanks
It said so on another thread for talktalk, so it should work for pipex. maybe.
Posted on Dec 02, 2007
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
The internet red light comes on on the d link modem regularly- sometimes for hours, rebooting does nothing often- it was supplied by aol DSL 2640R- I have had it for about six months and gradually the...
hi der... usually this kinda issue most of the time lies with the service provider.. but also to play safe...if can u may try to get another modem to test the connection. well internet light turns red . possible reason :
DSL keeps disconnecting - Frequent intermittent causes ur user id and password to be erased and therefore u need to reboot or may need to configure back
2nd : u may sometimes face night dc , if tats the case its the ISP circuit problem.. ask them to come and change the circuit which gives u intrnet access.
3rd : ur modem unable to save ur configuration ... therefore ur modem mite be at fault
or u can contact the respective modem vendor to check if ur modem is at fault before calling ur isp .. this mite help u pal...
TC...
Jul 07, 2009 | D-Link Computers & Internet
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Wireless connection
Check the Linksys web site for the manual. Follow the directions. Linksys routers have very easy set up routines and are designed for the novice.
Oct 31, 2008 | Linksys Wireless-G Broadband Router
SMC7901BRA Modem + Router Cannot connect
The Linksys router can be communicated with by going to Start>Run>type 'http://192.168.1.1' and when the logon screen appears use 'linksys' for username and 'admin' for the password. There you can reset defaults, view status, configure all router functions, et al, including restore defaults. Pressing the little reset button has reset levels that vary with the amount of time it is pressed -basically discharging a capacitive charge. Remember that cable modems use DHCP whereas DSL uses PPPoE. ~Steve
Oct 18, 2008 | SMC WIRELESS-G SMCWPICG 802.11G EZCONNECT...
Dlink di614+ settings
mohan, had some info from BSNL, you really should have an ADSL modem from them, which could be a modem router, check on that too.
Jun 22, 2008 | D-Link AirPlus DI-614+ Wireless Router
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Speedtouch 576
Have you tried to reset the device using a pin or paperclip, this should restore the device to factory settings and allow your new internet service provider help you with the setup to connect to thier service.
May 12, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
RCA Thomson Digital Cable Modem (DCM305R) Logo
115 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
