Question about HP DeskJet 5550 InkJet Printer
My printer has gone A-wall
My printer for work was working fine, until it just basically will not print anything, will not automatic feed paper, the lights for the ink keep blinking and the cartridges automatically move to the complete right of the printer. When I try and move the cartridges back to there proper place, the paper feed light comes on.
So my worry is how in the world do I fix this problem?
  • 16 more comments
  • Anonymous Nov 05, 2007
    same problem...blinking lights...cartridges to the right
  • bless Nov 13, 2007
    the light is not blinking. but paper is not feeding thru printer
  • Anonymous Nov 19, 2007
    ink light keeps blinking, won't print,
  • Anonymous Dec 17, 2007
    Same problem, blinking lights and it won't take any paper.
  • Anonymous Dec 19, 2007
    2 BLINKING LIGHTS. TRIED PAPER JAM
  • Anonymous Feb 13, 2008
    deskjet 5550 printer cartridges to the left...won't move two lights blinking middle and bottom. I have tried all the regular routes with all the trouble shooting and it finally says call a service man.......
  • Anonymous Mar 13, 2008
    same
  • Anonymous Mar 14, 2008
    after powering three led resume, power & ink continoiusly blink
  • cnchong Apr 11, 2008
    all three lights are blinking and will not print anything.
  • phantom8646 Apr 16, 2008
    My ink cartridge light is on and the resume and on/off lights are blinking. Nothing will print
  • Anonymous Apr 23, 2008
    Two lights continue to flash the resume and the power button
  • Anonymous Jun 02, 2008
    Same problem.
  • Anonymous Jun 12, 2008
    two lights blinking will not print
  • bennie21 Sep 09, 2008
    I have the same problem but the print cartridge stays to the left.
  • HP5550Fan Oct 17, 2008
    ink light blinks---nothing prints---i love this printer--is there no solution??!
  • Anonymous Dec 08, 2008
    same problem and I can't seem to find anything to fix it.
  • konchogrinch Jan 30, 2009
    Have toner and paper.
    Both light keep blinking.
    Can not clear lights my pushing buttons.
    When lid is open cartridges stay to left side of tray.
    Lid sensor is working.
  • Anonymous Feb 08, 2009
    same, but the paper light doesn't come on when we move the carriage
  • 3 Answers
I had the same problem but i finally figured it out
1. open the cover
2. pull the ink cartrage thing to the right while you push the center paper feed button
3. it should move now
Posted on Feb 13, 2009
    Genius:
  • 2,985 Answers
Try www.fixyourownprinter.com
Or check you manual for a reset routine.
Posted on Oct 19, 2007
When we try to print keeps saying load paper even although there is paper in feed tray. We have tried removing and replacing apper still same problem Printer just does not seem to register that there is...
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Good Luck!!!!!
Sep 24, 2011 | Lexmark X4530 InkJet Printer
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
My printer has the blue light on the lightbult and low toner (but ink is fine) - it will not print anything. The stuff sits in the print queue and i have to eventually delete it. The report will print...
My work-around for this problem is to feed paper in manually through the front. I turn the printer off and make sure all paper is out of the printer. When you turn the printer on - and the blue light stays lit (if it doesn't turn it off and wait - I've had to wait quite some time sometimes).. then manually feed 1 sheet of paper in the manual feed tray at the front. When the paper is inserted... you should be fine to print - and keep feeding paper in until you get your job. If you miss - you might need to hit the "continue" (triangle button)..
I've been trying to find out why mine locks up - and why it keeps jamming - but this is a tried and proven menthod - althought it is annoying it might help you for now.. Good luck
Sep 02, 2011 | Lexmark E250dn Laser Printer
X8350 InkJet Printer: my LEXMARK x8350 CONTINUALLY GRABS MORE THAN ONE S...
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
May 17, 2010 | Lexmark X8350 InkJet Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
C3180 feeding paper but not printing
I ended up unplugging the unit for a few minutes. It fixed the problem...
May 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Epson DX8450 not printing
are you using leopard os x? when you said you loaded the driver for the printer, did you use the disk that came with the printer?
Apr 03, 2008 | Epson Stylus DX4850 All-In-One InkJet...
Media Jam Fuser
I got that error turning off the machine in the middle of printing, opened the door to back, unlashed the 2 green tabs to the final heat roller towards the top and there was my page. i gently pulled it out error gone.
but in your case sounds like the paper is having a hard time feeding through all your rollers or the first one... in that case it has to torn down to the first roller and inspected for paper pieces , what ever, and I clean the rollers with laquer thinner rubbing hard on the black rubber until that high gloss is gone.
Jan 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
HP DeskJet 5550 InkJet Printer Logo
522 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
