Question about Panasonic PT-51HX41 51" Rear Projection Television
1080i panasonic got the convergence in order afte 2 weeks..now i have a beautiful pic in the center of the screen not full side to side
  • 431 Answers
Hi I am Vortash Y ou may have the screen set to letterbox or 4.3 format instead of wide-screen or 16.9 check your manual before you make alterations .. if you have no manual you can download one free of charge from .. http://www.safemanuals.com
I hope this is of help Regards Vortash
Posted on May 22, 2009
I'm getting a green / red separation on my screen now. Nothing I do seems to help. This a 2002 projection, HDTV 1080i, Cinema Vision unit.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Hi!!! my Tv is a Panasonic HDTV 1080i BBE High definition this is not a flat screen, the problem that it has is that the screen is not working well it looks like bouble imagen, what can I do?
I have never heard anybody refer to their tv as looking like a "bubble image" in the 15 full-time years that I have been a television technician, but all I can assume, is that you have a convergence problem, and you will need to replace both convergence ic's, and possibly some resistors. Approx. cost to repair by proffesional would be around $300.oo.
Nov 02, 2010 | Televison & Video
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic hdtv projection colors will not line up
If only minor convergence issues, the setup menu has user controls for 9-point convergence. If it's major misalignment in just one color, you may have a blown convergence amplifier chip. Big bucks repair, unfortunately. Chipsare about 30-40 dollars apiece but labor will kill you if they'll even fix it on-site. Most try to order $700+ board which is no longer available. Teh they send yours out for -10 weeks at similar prices.
Jun 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Convergence Problems with red to left of screen.
Replace Both STKs convergence ICs number of part will be on them STK392-110 if this is the number use 180s To order Parts Go To www.electronix.com or Call 1-900-223-3205 These ICs are big black chips.
Dec 14, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
Feb 29, 2008 | Hitachi CP-S860 Multimedia Projector
Tv wont turn on
3 blinks corresponds to convergence ICs
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 11, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
COLOR PROBLEM
Is the pic full? Or is this pink square full and the pic seem squeed?
Jan 03, 2007 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
