Question about KDS Visual Sensations 190i 19" CRT Monitor
Dvd recorder ejects disk when i insert blank disk
Have used the same recorder many times for recording video on the exact same type of disk
0 characters
1 Points
Plasma tv connections
What you need is a device called a multi-switch. Here's a page which details some of the switches available with different satellite setups. You would hook up your sat recievers, your TV and your recorder up to the multiswitch:
Jan 08, 2008 | Computer Monitors
DVD Wont Eject properly
Sound like you might have a bad DVD drive the only recourse might be just replace the DVD drive. If it won't open.. most often you can use a paper clip to open the drive. There is usually a small hole near the eject button on the DVD drive where you can insert a paper clip end to open the drive and pull out the DVD. After removing the DVD you can test if the drive eject or not correctly with nothing in it. If it doesn't, have the drive replaced.
Nov 06, 2013 | Acer Computer Monitors
Can't burn cds or dvds
Your dvd drive is faulty
Jun 04, 2010 | Computer Monitors
I inserted a disc and it couldn't be ejected, but I was able to insert another dvd and it plays. The touch screen became not very sensitive and responsive. What happened to my first disc? And how can I...
There is always a small pin hole in the tray of the DVD. Insert a pin through it and the tray will open mechanically. After removing the disk press the tray to close it.
Nov 08, 2009 | Pioneer AVH-P4000DVD Monitor
CD drive wont read blank or music CDs
It sounds like the drive is ready for replacement. It may be that the laser lens is dirty so the drive never detects a disc, or it's gotten too weak from age and use. Replacement drives are very cheap, so the best thing to do is replace the drive. You can get a DVD burner now at Newegg ( for $25.99.
Apr 17, 2009 | HP Compaq FS7600 17" CRT Monitor
Dvd drive wont read disks
Maybe It Can not support blank disks
Dec 15, 2008 | Dell 1505FP 15" LCD Monitor
Need help
first you need a music recorder like Audacity.
dependent on what you have, CD or DVD drive.
then you going to need a CD or DVD recording software like Nero, Roxio
recode the music from the internet, then you need to input the file to either Nero. or Roxio, then you can record them to the media.
Jul 28, 2008 | Envision EN-7220 17" Flat Panel LCD...
Vcr /dvd recorder trouble shooting
I have the exact same problem but have not been able to fix it. I'd love to know if you came up with a solution.
Apr 27, 2007 | KDS Visual Sensations 190i 19" CRT Monitor
Open Questions:
See all KDS Visual Sensations 190i 19" CRT Monitor Questions
KDS Visual Sensations 190i 19" CRT Monitor Logo
15 people viewed this question
Top KDS Computer Monitors Experts
Michael Thomas
Michael Thomas
Are you a KDS Computer Monitor Expert? Answer questions, earn points and help others
