Question about Sony DAV-BC150 System
DVD stuck in changer
I have 4 DVD's in my system & it will not change the DVD or open the door to remove them.  HELP!  How can I retreive my DVD's & play them again
I removed the outer case and then noticed white teflon selector
was not catching the each tray because it did not extend as far as it. the piece needs to be replaced. take it to a shop.
Posted on Aug 10, 2008
SOURCE:
How do you open the base unit to remove the cd changer magazine
The top cover is held on with 4 clips (similar to those on a car door card) so needs to be gently prised off, this will expose screws etc to enable the bottom cover to be removed.
Ive done this with my system but it does not really help solve the problem, I still can't get to the jammed disc!!
Jul 07, 2014 | Bose Lifestyle 30 System
3 cd's are stuck in player and the 5th changer won't open
Unplug it from the wall and give it time to power down. When you plug it back in it will reset itself and the changer will open. Pretty much the way a computer resets itself when you unlug it completely. Also works on my DVD player when it jams up
Sep 12, 2012 | Panasonic Audio Players & Recorders
5 disk changer dvd/cd shelf system is stuck! shelf 2 & 4 will not retract completely. Is there a reset button for the shelves so that they will open and retract like they are supposed to? Shelves 1, 3,...
Not usually so you may have to dissasemble a little to see if the discs can be removed! Do the discs have any labels on them that are to thick? Thats a big "nono" with the magazine designs!!!
Apr 19, 2010 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
U put disc in nowt apns, the 5 eject buttons flash continiously. so disc stays put , stuck in unit. has 2b removed to retreive disc
I had the same problem, but after reading this post... I gave it a good whack and the CD popped out. After that it worked fine.
Give it a try!!!
Nov 23, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
One of the discs is stuck in the disc changer. When I try to retreive the disc it makes a whirling noise
unplug the changer and open it up most of the time you can move the disc back in to the magazine
Jul 12, 2009 | 2002 Isuzu Rodeo
DVDs stuck in factory-installed 6-disc DVD movie player
Disclaimer: I am not a professional. This is an account of what I did to replace my DVD changer. If I had been offered the $450 installed option, I would have taken it.
According to the boys at Car Toys and the dealer, once these DVD changers go, they have to be replaced. The dealer quoted me $705, but I found one on E-bay from a highly rated seller for $400. I was able to pull out the DVD changer by popping off the trim betwee the DVD player and the cup holder, and then removing two screws. Note that it may help to remove the cup holder.
Once those two screws at the bottom are removed, it just takes a firm tug on console shell below the DVD player for the whole face of the console to come off. Disconnecting the airbag indicator connector will allow the console face to be pulled far enough away to get at the DVD changer. All connectors have a tab you need to press while pulling.
Two more screws need to be removed to get the DVD changer out. With those screws removed, another firm tug and wiggle will release the DVD changer. You'll probably hear a metal popping sound, which is just the rear grounding tab (I think that's what it is) pulling free from the cage.
Once you can reach the two wiring harnesses behind the DVD changer, pull on the wire bundle to give yourself some slack to work with, while not stressing the cable assemblies too much. Disconect the two connectors at the back of the DVD changer. At that point the DVD changer can be removed, and you can search on E-bay for the part number. My unit had a complete wiring diagram for the two connectors on the sticker, but I couldn't find anyone with the right connectors to install an aftermarket system.
I haven't received the new part yet, so I'm a little nervous about the correct order of connector installation. I'll probably pull the battery terminals while installing the new unit, but here is where you are on your own. Good luck.
Mar 14, 2009 | 2005 Chrysler Town & Country
Sony Home Theater 5 DVD changer, was dropped in transit
if you know how to open it, remove the top cover( a couple of screws on the rear) and remove two connectors, one being a ribbon cable and the other a multiple wire connector. If it still does the protect, then it is not from the dvd mechanism but a fault on the board.
Jan 17, 2009 | Audio Players & Recorders
Door will not open or close
i ended up retrieving the dvd out of mine after it quit coming on by taking the top cover off and taking the cover off the dvd it just snaps in place by clipping on each side.
Feb 17, 2007 | Emerson EWD7003 DVD Player
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
pls take the system to authorised showroom to get it reapired as the tracking system is not on its tracks ,pls donot try it at home as u will ending up damaging ur system
Jun 04, 2006 | JVC TH-M505 System
Sony DAV-BC150 System Logo
165 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
