Question about Frigidaire ATF6000ES Front Load Washer
I am getting a PAU code and it will not let me continue.
I am getting a PAU code and it will not continue
  • tsiebert May 22, 2009
    Thanks for suggesting.
  • 11,896 Answers
Possible cause: inlet valve, pressure switch or control board failure.
Possible solution: Do not open door, select drain/spin to remove water, restart cycle.
Posted on May 22, 2009
Machine stops and PAV appears on the panel
Thank you for your post, campy chaney!
I understand that your Frigidaire washer is displaying an error code of "PAV". "PAV" is not a valid error code, your washer maybe displaying a "PAU" error code. It could be a possible issue with a low light on your LED panel. If it is a "PAU" code that could be an interruption within your cycle. I would suggest performing a reset on your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. When you restore power to your washer and continue receiving the "PAU" code I would suggest having a professional technician out. This could be a possible problem with your control panel, door latch, or door strike. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 06, 2015 | Frigidaire ATF6000ES Front Load Washer
ATF8000FS1 washer is stuck in pause. Any suggestions?
Hi friend, thanks for your inquiry!
If your washer continues to display an error code of "PAU" it could be an issue with your door lock but if the door strike is not sitting properly within the latch your washer will continue to provide the error code "PAU". Additionally, if your control panel is registering that the door is closed you may continue to experience the "PAU" code. I would recommend having a professional come and properly diagnosis your washer to prevent any unnecessary part purchases. I hope this is helpful. -OOS
Oct 12, 2014 | Frigidaire Affinity ATF8000FS
Pau 12 flashing frigidaire
Hey friend, thanks for your inquiry!
I see off your post your Frigidaire washer is showing a "PAU 12" code. Typically "PAU" stands for pause which means the cycle has been interrupted. I would open and close the door to assure that there is a proper connection between the door strike and door latch. If you check that and still receive the "PAU" I would recommend a reset, which can be done by flipping the household circuit breaker off for roughly ten minutes. Hopefully this is helpful. -Matt
Aug 07, 2014 | Frigidaire Washing Machines
How to fix a Kenmore dryer model 417.8112 with error code pau
Is your washer still full of water? You may have something in the drain motor, that would also cause the error code 41 issue. I'd first check for an obstruction in the drain motor itself. Its very easy to get access to the drain motor. Lots of times I see these get clogged with stuff ...
Jul 27, 2014 | Kenmore Dryers
Fridgidaire affinity washer Pau lights every time hit start
Did you check to see if the water outlet valves (that connect to the washer) are Good, Turned On and water comes out? Anyway you are not getting water into the machine either from that or you have 2 (Hot and Cold) water inlet valves are bad (very rare for both to fail). The fault code is usually "PU", not PAU!
Jul 26, 2014 | Frigidaire Affinity ATF8000FS
Code pau
For pause mode, just push the start/pause button again.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 970
Do you have the customer user manual indicating what the Error PAU mean? I do not have my Error code log at hand as i read your post sorry. Provide as much info to get others to help you.
Most Error codes will lock out you machine, for safety reasons..so it wont start.
Oct 16, 2013 | Dryers
FRIGIDAIRE LTF2940FS1 Error Code "PAU"
Hi
PAU is short for pause; the machine detected something wrong so it paused itself. Unplug it from the wall for a minute and plug it back in, it may reset. Once you plug it back in, it should display a Numerical code. You need to find out what's that error code mean.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Dec 01, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
642 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
