Question about E-Machines eMachines Desktop PC
NTLDR is missing
I used RESTORE CD Ver. 1 on my emachines Model 4510 (both CDs).
"SYMANTEC Ghost 7.0
Error ! Cannot open R:\T4510.gho OK
Error ! Cannot open ghosterr.txt OK
Invalid Dump File. If problem persists, contat SYMANTEC Tech Support at http://service.symantec.com"
After the Restore CDs said restore was comple, it then asked if I wanted to to to comand line or reboot.
After I go to reboot, I get "NTLDR is missing. Press ctl+alt+del to restart" And it loops back to "NTLDR is missing."
On line NTLDR instructions are over my head. I can't afford a fix. I'm selling the computer to pay rent.
  • simonson024 May 23, 2009
    Thnaks for the reply. Every time you say "make sure..." you need to tell me hoe to make sure. For example, if it's trying to boot from a non-bootable source, how do I get it to do so? For you ees easy, for me ees dificull. but I'll try and get back to you.thanks again.
  • 11,896 Answers
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
Posted on May 22, 2009
2 Suggested Answers
dante777
  • 623 Answers
SOURCE: NTLDR is missing. Press ctl+alt+del to restart.
I assume you are using Windows XP. This is what you do:
Windows XP users
  1. Get a Windows Installation CD. It doesn't have to be yours, anyone will do.
  2. Insert the Windows XP CD into the computer.
  3. When prompted to press any key to boot from the CD, press any key.
  4. Once in the Windows XP setup menu press the "R" key to lauch the Recovery Console to repair Windows.
  5. Log into your Windows installation by pressing the "1" key and pressing enter.
  6. You will then be prompted for your administrator password, enter that password. If you have none set, just press Enter without typing anything.
  7. Copy the below two files to the C:\ directory of the primary hard disk. In the below example, the files from the CD-ROM drive (which in this case is "D:\" are copied to the C:\ drive. This letter may be different on your computer.
    copy D:\i386\ntldr C:\ (hit Enter)
    copy D:\i386\ntdetect.com C:\ (hit Enter)
  8. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If you have any more questions or this is not clear to you, just come back here and leave a comment - I'm happy to help.
Posted on May 23, 2009
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Every time I try to backup my c: drive using
turn of system restore in windows 7 and then try with norton make sure ur disk has enough space and make sure windows default backup is disabled
Jan 07, 2010 | Symantec Norton Ghost 15.0 Full Version...
Windows XP users
May 22, 2009 | E-Machines eMachines Refurbished EMA...
Reformatted computer, found files with GHS & GHO,how to recover?
Hi 'jen2x':
I’m Melinda and I represent Symantec’s PR Department.
Norton Ghost has the following key features:
  • Full system backup (disk image)—Backs up everything on a hard drive or partition.
  • File and folder backup—Backs up only the specific files and folders you choose rather than saving an entire drive.
  • FTP backup—Copies recovery points to a FTP site for easier offsite backup management. NEW
  • Offsite backup—backs up your files to NAS (Network-Attached Storage) devices. NEW
  • Symantec ThreatCon integration—triggers incremental backups whenever ThreatCon reaches a specified threat level. Great for computers without virus protection. NEW
  • Incremental and differential backup—Backs up only files that have changed.
  • EXCLUSIVE! Google Desktop™ integration—Makes data recovery even faster with searchable backup indexes.
  • LightsOut Restore—Restores your system with an on-disk software recovery environment—no bootable CD required.
  • EXCLUSIVE! Remote management—Controls other Norton Ghost installations (12.0 or higher) on your local area network.
  • Advanced compression and encryption—Minimizes storage space and helps keep sensitive documents safe.
To download the 14-day trial of Norton Ghost, please visit our site here: http://nct.symantecstore.com/fulfill/0184.074.
To find out more about Norton Ghost, please visit our site here: http://www.symantec.com/themes/ghost/index.jsp
Regards,
Melinda
melinda.jenkins@ar-edelman.com
http://twitter.com/MelfromSymantec
May 15, 2009 | Symantec Norton Ghost 2003 for PC
Norton ghost 14... I cant recover back up...
Ghost saved the drive information in an image file.  Whatever you named your backup you would see *.gho, *001.gho, *002.gho.  That is your whole hard drive in a spanned image file.  Ghost Explorer is what you need to open and view these images and you would be able to extract files as your would from a zip file.  There are no restore points as you would think using Windows Restore.  Only the raw hard drive information as it appears on your dive now.  I'm  not sure if Ghost Explorer is provided with the home edition as I'm used to the enterprise for my work.
let me know if this helps
Apr 30, 2009 | Symantec Norton Ghost 14.0: Windows
Emachine T1220 with only one restore cd...what else can I do?
1 Solution for "When ever i plug my eMachine into my dj system through a usb sound card it hum
Apr 17, 2009 | E-Machines eMachines Desktop PC
Need software
gho is the extension of backup file format saved by Norton Ghost, that is Norton backup program.
GHO file extension can only be opened with Norton Ghost, and restored on an hard drive, after extraction you can save data on optical support using any CD burner software.
You can download Norton Ghost below:
Norton Ghost
Feb 27, 2009 | Symantec Computers & Internet
Emachine t2042
*.GHO files are Norton Ghost images that are used by some OEM's to create a factory defuault image. When you restore this it should set the pc back to the same condition it was in when u purchased it however this will erase all your personal data on the drive.
If you are getting this error it means that the ghost image you are using to restore the PC is corrupted and cannot be used. eaither the CD is trying to read this data from a corrupted restore partition or the restore disk you have is bad (sometimes the disk may look fine- no scratches or anything and still be bad)
Try checking the disk for scratches or smudges but if you dont find any you can clean off the disk you will have to contact e-machines for a replacement disk.
Jan 09, 2009 | E-Machines eMachines Desktop PC
COMPUTER
dear sir
for u need the best way is use norton ghost it's make yr full harddisk or partation full data image call .GHO file and this software also give a recover disk image it's help u..
thanks
Please Vote
jo_chinmay
Dec 31, 2008 | Computers & Internet
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
E-Machines eMachines Desktop PC Logo
697 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
