I used RESTORE CD Ver. 1 on my emachines Model 4510 (both CDs).
"SYMANTEC Ghost 7.0
Error ! Cannot open R:\T4510.gho OK
Error ! Cannot open ghosterr.txt OK
Invalid Dump File. If problem persists, contat SYMANTEC Tech Support at http://service.symantec.com"
After the Restore CDs said restore was comple, it then asked if I wanted to to to comand line or reboot.
After I go to reboot, I get "NTLDR is missing. Press ctl+alt+del to restart" And it loops back to "NTLDR is missing."
On line NTLDR instructions are over my head. I can't afford a fix. I'm selling the computer to pay rent.
Comments:
May 23, 2009
- How do I delete this problem? The Problem is not related to the motherboard, as stated above, and I don't know how to delete the product entry!
May 23, 2009
- Thanks, I'll try it and get back to you. The down computer is across town with no internet. So I have to print directions and hand carry.
I assume you are using Windows XP. This is what you do:
Windows XP users
Get a Windows Installation CD. It doesn't have to be yours, anyone will do.
Insert the Windows XP CD into the computer.
When prompted to press any key to boot from the CD, press
any key.
Once in the Windows XP setup menu press the "R"
key to lauch the Recovery Console to repair Windows.
Log into your Windows installation by pressing the
"1" key and pressing enter.
You will then be prompted for your administrator password,
enter that password. If you have none set, just press Enter without typing anything.
Copy the below two files to the C:\
directory of the primary hard disk. In the below example, the files from the CD-ROM drive (which in this case is
"D:\" are copied to the C:\ drive. This letter may be different on your computer.
will not start. makes a beeping noise. will sometimes start after several attempts. will not go to...
(More)
will not start. makes a beeping noise. will sometimes start after several attempts. will not go to desktop.
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. ...
(More)
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. I've tried using a repair program but it says the C: partition1 is unknown and cant use this area.
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm...
(More)
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm pretty sure it freezes. What should I do?
