Question about Sewing Machines
Necchi 536FB Thread from bobbin will not come up when the needle goes down. I have no manuel.
SOURCE: sewing thread won't pick up the bobbin thread
are u holding the end of the top thread hen needle goes down?
it helps :)
Posted on Mar 17, 2009
SOURCE: Model 3205 FA not picking up bobbin thread, needle
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
Posted on Aug 20, 2009
RickE1
  • 202 Answers
SOURCE: I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Posted on Aug 29, 2009
Sewtech1
  • 69 Answers
SOURCE: The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Posted on Jan 22, 2010
  • 26 Answers
SOURCE: bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Posted on Apr 08, 2010
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
Necchi 544 - won't pick up bobbin thread.
Timing is out...probably due to a recent jam...this is an overview.http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Serviced more than 2 years ago ??
Overdue
Nov 08, 2011 | Sewing Machines
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
Bobbin thread will not pick up
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Rick
Aug 24, 2009 | Necchi Sewing Machines
Model 3205 FA not picking up bobbin thread, needle goes down but doesn't pick up bobbin thread, needle not bent, macine was working fine then all of a sudden bobbin thread stopped. Can't even pick it up to...
best regards
Aug 15, 2009 | Necchi Sewing Machines
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Bobbin/raceway and timing problem; Necchi 3577
ok.....without the bobbin case in and a fresh needle in, turn the machine to the side and turn the crank wheel counter clockwise, the hook of the machine should bypass the cusp of the needle, thats the part of needle that is by the eye and curves in alittle, if it is not the timing is off, try to adjust this by adjusting the needle bar, this is not a easy easy repair but takes patients, im assuming that, thats where it was thrown off timing
Jan 21, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
185 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
