Question about Apple iPod touch
It's all black with a white apple sign
My iPod touch is stuck on a screen that's all black with a white apple sign in the middle of the screen. It keeps loading then blacking out and then loading again. Some please help me out.
    Sniper:
  • 89 Answers
Ok try reseting it and no reseting the ipod dose not erase it hold the power and home button at the same time for at least 10 sec or untill the ipodreset it should sjut off and a few sec later you should see the apple logo hope this helps
Posted on Jul 30, 2009
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
Ipod touch half white screen
This is actually really easy to do.
This called a hard reboot.
All you have to do is hold the home button and the power button down at the same time for 30 to 40 seconds or until you get a Apple sign on your screen.
This will reboot your ipod.
If this does not work there is one other thing you can try to do.
Hook your ipod touch up to your computer that you use itunes on.
Itunes will detect a problem with your ipod.
You can try a restore of your ipod from your computer.
If this does not work its time to return or send your ipod back to apple so they can repair it.
hope this helps
Sep 22, 2012 | Apple iPod touch 4th Generation MP3 Player
Ipod touch will not turn on
Thank for contacting Fixya, I will be glad to assist you.
What you can do, in order to resolve this issue, is start by resetting your iPod Touch
(Note: this does not remove any settings, data or media you have installed in your device)
• To perform a hard reset, press and hold your Sleep and Home Menu buttons for approximately 10 seconds.
• Once your screen goes black, release both keys. (If you see a white Apple logo before you release the keys you have held the keys to long and will need to start the reset process once again)
• The next screens you should see after the black screen, is the Apple logo screen followed by the main screen.
Let me know if this helps.
Regards,
-The MacTechTrainer
Nov 06, 2011 | Apple iPod touch
My ipod works, it just has a white screen, i tried holding the sleep/wake button menu, and restoring it and still have the same white screen...
Open Itunes on your computer. Unplug ipod if it's plugged in.
Turn Ipod off (with sleep/wake and home button).
Hold home button down and simultaneously plug in the Ipod again.
Keep holding it (home) until the screen is an apple with a usb underneath it (Itunes sign).
Then in Itunes choose restore your Ipod.
If it's jailbroken go through the Jailbreak process again.
Oct 05, 2010 | Apple iPod touch
Frozen
press the MIDDLE BUTTON and MENU button at the same time
or
press PLAY and the MIDDLE BUTTON at the same time till you ipod resets
Jul 02, 2009 | Apple iPod mini 2nd generation MP3 Player
Stuck on black and white Apple logo screen
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode http://www.youtube.com/watch?v=bITIiGswjFI
. itune must be run on PC.
It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
This process will solve your problem 100%. I have solved same problem for ipod touch. Follow this video http://www.youtube.com/watch?v=AQk4-krrNVk
Thanks.
If my solution help you please vote up me.
May 22, 2009 | Apple iPod touch
Locked ipod
 Hi
if your ipod froze, just hold down the middle button for one second.. still holding it, press and hold the menubutton for 6 to 10 seconds. then the screen should turn black and after a few seconds a white apple should appear and the i-pod will restart and go back to normal.
please rate my suggestion...
Ipod Touch 8GB Screen Problem
the white apple is the start up but the white flahes is weird
Apr 04, 2009 | Apple iPod touch
My 1st gen ipod touch has a white screen that's stuck and nonresponsive
my itouch ipod 16gb was slammed down and has a white screen
Apple iPod touch Logo
135 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
