Question about Acer TravelMate 202T Notebook
Lock on screen
Need help here goes a symbol of a lock keeps showing up on pc screen it does go off be reapeers right in middle of screen please help
How do you switch the Wi-Fi on, on a Zoostorm VME50 laptop
Zoostorm VME50 Notebook
  • This unit is identified by White system lights, a white light in the power button, and three symbols lit white to the right of the power button
  • To enable the wireless, please press the middle wireless icon to the right of the power button whilst logged in to windows. These three symbols are touch sensitive. After pressing the button, a grey symbol will appear on screen for 'WiFi'. Click this and it will turn green to show it is enabled. The wireless is now enabled.
Good luck.
Semper Fi,
Z
Feb 15, 2018 | The Computers & Internet
Unlock
The Lock symbol needs to moved to the right to the unlock symbol by your finger.
This will then load the desktop and activate the touch screen.
Support Troubleshooting Guide
Apr 18, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
How to disable ipod
Your iPod touch shows a lock symbol on the top of the screen when it's in lock mode. This protects your iPod from being accidentally bumped on or off while you're focused on other things. Getting in and out of lock mode is somewhat intuitive, but can take a couple of tries the first time.
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off.
This helps save battery life if you have it locked while it's asleep.
It prevents your music from turning off if you've put your iPod in your pocket. However.
it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right.
Mar 24, 2013 | Apple iPod touch
It has a locked in the screen
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off. This helps save battery life if you have it locked while it's asleep. It prevents your music from turning off if you've put your iPod in your pocket. However. it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right. Hope this helps.
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
CL is coming across the screen. i don't no what to do? i have tried everything from unpluging to cleaning the rubber. also i tried to run with using tide for cleaning and nothing is working. need help.
hi.
CL normally means the child lock is active. look for a lock symbol, either next to a button, or in the middle of a line connecting 2 buttons on the front of your machine. press and hold the button(s) for five-10 seconds until the CL goes off. hope this helps
Aug 16, 2011 | LG Washing Machines
Epson P5000 won't switch one
its software have been frozen or crupted connect it to pc and upload a software
Mar 23, 2010 | Epson P-5000 Digital Media Player
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Lock/unlock symbol appears in the middle of the screen
5-22-09 Same problem last month. I had the problem a year ago for a month, then it stopped, reappearing this last month. Last week, I finally called support...I was accidentally transferred to a Dell "internal" technical support department...happily a very diligent technician spent a bit of time with me for free...for same problem, even though he confirmed I was over a year past all warranties. He confirmed this was a monitor problem (not virus, malware, etc.). He also confirmed their standard "guidance"/solution for this monitor issue (if under warrantee) is to replace the monitor (i.e. not attempt to fix it). New monitor needed. But problem again gone for last 10 days. So, when fully irritated, buy new monitor.
Apr 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Power Button
First thing to check is the hard power button on the back to the top right of the battery of the MC50 switched to the right with no red showing?
Aug 30, 2008 | Symbol MC50 Pocket PC
Monitor control lock problem
Replace the small 78L05 regulator 5V supply to micro.
Jan 13, 2008 | Computers & Internet
Acer TravelMate 202T Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
