Question about Husqvarna Garden
One side of the hydrostatic want work
I have a cz3815 residential zero turn and only one side of the hydrostatic wants to work whats wrong
    Problem Solver:
  • 11 Answers
Have you checked the filter on the hydro?
Posted on May 23, 2009
My mower keeps going when it is in neutral...why?
If it's a zero turn then the right side handle may need adjustment...refer to owners manual...or right side hydrostatic motor is bad and not going into nuetral.
Aug 15, 2016 | Garden
A diagram of the transmission on a cub /zero turn/tank
Michael, The dealer may print the diagram off for you, just try asking them nicely. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cub Cadet Riding Lawn Garden Zero Turn Tractor transmission diagram Google...
Cub Cadet Riding Lawn Garden Zero Turn Tractor transaxle diagram Google...
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
https://www.cubcadet.com/wcsstore/CubCadetCatalogAssetStore/Attachment/owners%20manuals/residential/ZF50_02005033-08-1.pdf
Jul 02, 2016 | Cub Cadet Riding Lawn Garden Zero Turn...
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Toro Zero Turn SS 4200 - how do you drain/fill the fluid in the hydrostatic pump? What type of fluid?
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Oct 02, 2012 | Cars & Trucks
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I recently bought a husqvarna cz3815 zero turn 38" deck 15 horsepower used. it does an ok job but seems like could be better as far as power. i cant throttle up all the way when the blades are engaged,...
If you put the trottle lever all the way up that is the choke for just starting the engine. So 3/4 of the way is the highest rpm level.
Aug 24, 2010 | Garden
On my cu cadet zero turn only the left side turns and the right side moans but wont move ever with the release lever to free wheel released
Check the hydraulic oil level for the hydrostat drives(if it has a reserve tank located under the seat. Some ZT's don't have the reserve tank. Don't over fill that tank. 1/4 inch above the bottom is all it needs.)
Also, check the steering arm bolts. Very often they work themselves loose and the arm doesn't pull the valve rod that controls the hydrostat unit.
Oct 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Aug 23, 2009 | Garden
Garden Logo
271 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
