Question about Magic Chef Dryers
Has a bad rumble while running sounds like a chopper flying over then when it shuts off has a clunk and sounds like a sudden stop.
Magic chef dryer model #ye206kw has a bad rumble while running sounds like a chopper flying over then when it shuts off has a clunk and sounds like a sudden stop. dries fine just sounds bad
  • Magic Chef Master
  • 3,361 Answers
Replace the blower wheel on the motor.
Posted on May 23, 2009
Ye225 Magic Chef suddenly stopped working. wondering if I can troubleshoot and repair myself..
you can check this site out as it is good:
http://www.applianceaid.com/gas_dryer.html
Hope this helped Tim
Oct 16, 2010 | Magic Chef CYG2000AWW Gas Dryer
I own a Magic Chef model YG225LV and the drum stopped spinning. Looks like I need to disconnect the vent and gas lines and open it in back to get to the belt for replacement. Can you confirm that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, on most dryers that is correct...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | Magic Chef Dryers
Magic Chef electric dryer YE20HN3 doesn't stop automatically. Timer? Just keeps going and going.
Yes, it sounds like a bad timer...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 23, 2010 | Magic Chef Dryers
No power (electricity) is getting to the machine.
It would either be a poor wire connection (usually at the terminal block where the cord attaches) or a bad motor that is overheating and shutting down. The motor is part number 2200376 and runs about $140.00.
Apr 23, 2010 | Magic Chef CYE3005AYW Electric Dryer
Dryer stopped working, sounds like timer still running
I suspect it is the thermal fuse. Seen here. You will need to determine what caused it to blow. on these machines the blower wheel is notorious for getting loose and causing the element to over heat. This makes the heating element shut down faster and takes a long time to dry the clothes. 7fc125e.jpg
Apr 10, 2010 | Magic Chef CYE4000AWW Electric Dryer
Magic Chef electric Dryer won't start
Do you have power going to the receptacle. You can first go to your house panel and look for the circuit breaker for the dryer (usually a 30 amp 2-pole brkr.). It could be tripped. So first, put your dryer in the off position. Next, go back to your circuit breaker in your house panel. Turn off the breaker, and then turn it back on. This should reset the circuit breaker for the dryer. Then go back and try turning on your dryer. If this doesn't work, feel free to contact me again. However, this would seem to be it. Good Luck to you!
Mar 28, 2010 | Magic Chef Dryers
HUM NOISE OCCURES WHEN TURNING KNOB TO LEFT BEFORE PUSHING KNOB TO START- STOPS WHEN POINTING TO OFF POSITION - MODEL GYC4000AWW . DRUM DOES NOT TURN
it sounds like you have a bad motor and door switch. the unit should not run unless you push a start button. the humming noise is the motor. either something is blocking it or your motor is bad,
Oct 12, 2009 | Magic Chef CYG2000AWW Gas Dryer
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Jun 17, 2009 | Magic Chef CYG4000AWW Gas Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Dryers Logo
186 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
