Question about Johnson Boating
Johnson Outboard motor. 3.3 HP.
It will start, but then it spitters and sputters for about 5 minutes and shuts down. Sometimes it will start again and sometimes it wil not. I have taken the carborator apart and clean it up. I have changed spark plugs and have put fresh gas in it. I have also made sure it had a spark and that all gas lines are clear. Can anyone tell me what i should check next. The water pump is also working. Thanks
  • Johnson Master
  • 3,498 Answers
Hey BK, Its still the carburetor!.... take it to a qualified professional.. there are TOO many tiny passages and jets that must be perfectly clean for a small engine to run properly..
Posted on Sep 26, 2017
joboo1
  • 257 Answers
SOURCE: 1991 Johnsoon 90 HP outboard hard to start, floods after stop
Hi, You did a good job of assessing the problem. It sounds like the float valve in the carb is the likely problem. This would overfill the carb when sitting, flooding the engine and the pressure in the bulb pump would go down as the fuel leaked out. Float valve should be investigated and that should Fixya!
Posted on Mar 13, 2009
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
finish line
  • 207 Answers
SOURCE: johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Posted on Jul 13, 2009
  • 86 Answers
SOURCE: Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Posted on Aug 06, 2009
rcalorisian
  • 313 Answers
SOURCE: Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Posted on Sep 08, 2009
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Evinrude 40hp outboard
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
May 17, 2017 | Boating
5 h.p. briggs and stratton outboard motor shuts off
This has puzzled me a few times in the past. It is most likely related to a fuel issue. If you have an external tank, make sure there is no debris or water in the bottom (looks like a big bubble under the gas), next I would check to make sure the fuel lines are not cracked allowing air to enter. This could also be caused by a bad o-ring at the connector on the fuel tank or motor or the connector is not securely connected.
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
2003 johnson outboard motor cranks but cuts out
can only say DUH .sounds like a battery problem or a starter motor .
Apr 22, 2010 | Boating
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Sep 17, 2009 | Boating
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
Johnson 1998 175 hp motor seems to be in safe mode
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Boating Logo
913 people viewed this question
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
