Question about GE (PSS26MSRSS) Side by Side Refrigerator
R/H door swings open too easily and hits counter behind door.
Right hand door (refrigerator section)swings open without resistance
    President:
  • 331 Answers
Hi LC,
Your fresh food lower door hinge cam assembly has failed and needs to be replaced. Not a big deal to replace, really... but you have to remove the FF door to get to it. <---which is VERY simple to do. But first thing first, right? You'll obviously need the replacement part on hand prior to the repair, so the part number is WR02X10779. You can see what it looks like here (you could also order it here if you don't have a local appliance parts retailer).
OK, now that you have the cam assy., Empty out all the goodies that you have stored in the FF door shelves. Then using a sturdy step stool, remove the upper hinge cover. Below the cover, you'll find three more screws, remove them (just so you know ahead of time... after you remove the last of the 3 screws, the door is no longer "attached" to the frame, so hold on to the door while removing the last one, OK?). Now all ya have to do is lean the door forward (from the top) and lift it off of the lower hinge/cam assembly.
Now that the door is off, all that's left to do is remove the old cam assy., install the new one and rebuild everything! Easy Breezy! You'll be in and out of this job within 20-30 minutes.
Oh yeah... one other thing. When you replace the door and are putting the top hinge back on, put all 3 screws in but don't tighten them yet. You'll need to "level" the door and THEN tighten them. Just lift the fridge door handle 'til the top of the door is level with the Freezer door, tighten the screws while holding the door in this position, deal? Cool.
Hope this helps!
SG
R/H door swings open too easily and hits counter b - 652df59.jpg
Posted on May 22, 2009
I have a kitchenaid refrigerator with single door on top and pull out freezer drawer on bottom. When I open the refrigerator door it will swing all the way open and hit the counter top . How do adjust it...
It sounds like your refrigerator is out of level in the direstion of your door hinge. Under the front side, in behind the louver at the bottom will be two adjusting screws. Either raise on the hinge side or lower on the non hinge side. Or both. this should get the door to the point you should be able to let it loose and the door should, from any position, shut by itself.
Hope this helps.
Dec 19, 2014 | KitchenAid Refrigerators
When I open bottom or top fridge doors they swing all the way open by themselves instead of staying put partially open
The fridge needs to be leveled better...
When the doors swing open then gravity takes over and pulls the doors open the rest of the way...
to fix this adjust the legs of the fridge so that it leans just a bit away from the hinge side and back just a bit...then the doors will swing closed by themselves...
The back legs may have to be shimmed and the front leg adjustments are usually right behind the front cover at the floor...sometimes there are screws there to adjust the back legs from the front also...
heatman101
Jan 16, 2011 | Kenmore 64802 Top Freezer Refrigerator
My GE side by side fridge door swings all the way open and hits my counter next to it. It progressively has gotten worse over time. Is there a "stop" that is bad or just a hinge issue?
there are door stops that snap off on the bottom of the door,the part number is WR02X10782 and they're like 8 bucks,two screws hold it in place
Nov 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling
if your talking about the damper vent door motor,it is behind the vent grille where the damper vent is and is controlled by the refrigerator temp adjustment control,sometimes these doors freeze open or shut from condensation,if this is the case take a hand held hair dryer and thaw and dry out door and hinges and then try adjusting temp asnd see if the door opens and closes now
Apr 19, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
GE Side by Side Frig Door Flies Open to Far
Look under the front of the fridge, should be some adjustments to raise and lower the wheels or feet for leveling. Level it with a level on the top, should help keep the doors from swinging.
Sep 13, 2009 | KitchenAid KSCS25FKSS Side by Side...
The refrigerator door swings open without resistance and hits the counter behind the door
Hi, Check the hinge cam and closer kit on the bottom hinge. See if there are any cracks or even part of the cam mising. They have a tendency to wear sown through the years. If this loks like the problem, please let me know and I can get you part #'s for you.
Vid
May 23, 2009 | Refrigerators
GE Side by Side Fridge Door Adjustment
Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Jul 02, 2008 | GE Refrigerators
Counter depth refrigerator
Do you have room to pull the fridge out from the wall, maybe just a couple inches? Pulling it out from the wall should give you more door swing without hitting the counter.
Let me know if this works for you.
Thanks,
Bill
May 16, 2008 | Refrigerators
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
722 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
