Question about Toro Lawn Mower With Toro Power Tools
Replacing front drive cable.
The cable to my Toro model 20016 broke. I purchased the replacement cable, however I can not get the plastic shroud off of the trans. to put the cable on. I do not want to break it as I do with most things I try to fix. LOL. Any help on this would be appreciated. Also if there is anything complex once I get in there, which I assume there isn't, let me know that too. Thanks. Matt.
My mower has two bolts underneath in blade housing.
hope this helps. Once, there no problems
Posted on Jul 23, 2009
Toro gts model 20016. Engine will not stop after hand bar released
adjust the cable to the stop on the end of the bracket behind the carby body
remove the recoil starter and replace the spring
Aug 28, 2016 | Toro Garden
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Feb 23, 2011 | Toro Lawnmower Lawn Mower Sp Drive Belt...
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Starter rope broke how do i replace it. toro super recycler mower. Removed the plastic engine cover and the recoil mechanism seems to be rivited down and I cant get in there to replace the rope. Please...
You have to remove the whole engine air shroud over the flywheel to gain access to the recoil and rope mechanism. If you need specific help on your exact model engine I need all of engine model type numbers 5 to 6 char then 4 char then 2 char i.e XXXXXX-YYYY-ZZ for B & S Honda numbers are by the engine oil port on the base of the crank case. Thanks for using FixYa, Kelly
Apr 22, 2010 | Toro Lawn Mower With Toro Power Tools
The cable for the front drive broke, where can I get a new cable. the cable broke loose at the top where it connects.
Note your Model Number and click HERE for parts drawings. Locate your part number and call your local shop for purchase.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Toro Lawn Mower With Toro Power Tools
Cable to front drive system to loose
that cable your pulling on has adjusters you need to adjust it and tighten it
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,490 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
