Question about Toro Lawn Mower With Toro Power Tools
I need to pull the fly wheel off of my lawnmower
I want to pull the fly wheel off of my lawnmower with out damaging it
    Problem Solver:
  • 11 Answers
Get a flywheel knocker. you will either place it over the threaded crankshaft top or thread it on. then, hit the knocker with a hammer while GENTLY prying the flywheel up.
Posted on May 23, 2009
Honda issy lawnmower engine will not stop once startedl
I suspect the braking pad and or mechanism around the fly wheel is worn, mal-adjusted or disconnected. Hint start at the bar you are supposed to pull down to the handle in-order to start the mower, follow the cable, check the spring loaded mechanism the cable connects to & then remove the recoil to examine the brake band. See if it works and if it has worn down. Repair/replace as needed.
Feb 27, 2016 | Honda Garden
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
How do i get the flywheel off to get to the points i have no spark
use a three prong pulley puller and pull it off before this are you sure you have points chek blad brake is disengaging befor pull fly wheel
May 13, 2012 | Briggs & Stratton Briggs Stratton...
What should the clearance be betwwen mag and fly wheel toro
The gap should be about .010 (Ten Thousandths of an inch), but truthfully, the way I set it is to loosen the coil bolts and place a shiny business card in between the coil and flywheel. Tighten the coil up snug against the business card and then remove it. This should set the gap close enough to the correct setting for you; done. Hope this helps and best of luck to you.
James
Nov 11, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Timeing pull cord rip out of hand when trying to start mower model 18m
what you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
Apr 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Electrical problem with my 1999 Scotts Riding Lawnmower
If the motor is trying to start but won't try removing the engine shroud and cleaning the magnets on the fly wheel and the two little prongs close to the fly wheel. They might just be rusted and not getting a good electric pulse to the spark plug. Also clean the spark plug wire end that goes on the plug. I use fine sand paper or emery cloth. Your choice.
Good luck and let me know if this works.
thanks
roundo4
Sep 02, 2009 | Garden
I want to change the pull crd on my 6.5 hp craftsman lawnmower
remove the engine shroud. Pull the cord all the way out. Put a screw driver into the fins so it does not unwind. Cut new cord and install through hole in shroud and the rewinder. Reattach handle to cord and hold onto rope and pull screw driver out. Slowly let cord rewind. Pull a couple of times to make sure it is working. While engine shroud is off us a piece of emery cloth or fine sandpaper to clean off the magnets on fly wheel and the two little prongs close to the fly wheel.
Good luck let me know if this helps.
roundo4
Aug 14, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Fly wheel needs to be replaced
Yes you do. If it's 4x4, i find it easier to pull the motor.
May 04, 2009 | 1989 GMC Sierra
1984 Cadillac Deville Ddiesel
You need to pull the starter out and check the drive gear. If the drive gear is no good you will have to replace the starter. Make sure the cogs on the fly wheel are okay. If the fly wheel is damaged you will have to replace the fly wheel.
Apr 25, 2009 | 1984 Cadillac DeVille
Starter turning engaging not start
 you need a shim, if its screaming your clearance is to great. Are you positive its the right starter?
Feb 19, 2009 | 2003 Ford Ranger Regular Cab
Toro Lawn Mower With Toro Power Tools Logo
299 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
