Question about Gigabyte 8I845PE-RZ (GA-8I845PE-RZ) Motherboard
Bios booting problem
My bios try to boot and sometimes i got display and counting my ram but its work only in few seconds and the power supply is turn off. i replace already the power supply with new one but still i got the same problem. i replace the battery of bios but when i switch on its not coming on. i have to return the old batterty in order to boot the bios for a few seconds only until the supply cut offs.... anybody can help me ????/ ist my mother board is faulty ???? thank you very much......... swordfish
  • CONSTANTIN SPYROU May 11, 2010
    It is difficult to tell yet. when you bought the computer did they give you a floppy disk called a recovery disk. Install it withthe comp. off, then turn on the power. The floppy disk should boot up and stop on drive "A:". If this works, then it is not the BIOS, but it does not mean that the motherboard is OK. Go and buy a cheap digital voltmeter (usually at Home Depo or other Hardware Store - Radio Shack would be rather expensive). Using the voltmenter you check the voltages as follows: +3.3V (Brown), +5V (Red), -5V (White), +12V (Yellow), -12V (Blue), +5V-SB (Purple), COMMON (Black), PS-ON (Green), PW-OK (Orange). I could be wrong but I still don't think that the problem is in the BIOS. Please get the info. back to me
  • Mohamed Omran May 11, 2010
    Have you checked your motherboard for any leaking capacitors?
    Novelist:
  • 118 Answers
Something is definately not right, but I am not convinced it is the motherboard.
You are saying the system shuts down while doing a memory test? I would replace the memory with known good, and known compatible with the system first.
Also double check the cpu and cooling system to be sure the cpu is not burning up.
good luck
tony
Posted on May 23, 2009
My dell inspiron M5030 turns on showing the dell logo and then it turns off
I would remove the power supply, battery, hard drive and RAM. Power up the laptop with just the power adapter and enter bios. If it goes to bios OK, select the default setting. Press F10 and let it try to re boot.
Remove the power supply and fit the RAM. Insert the power supply and try to boot. You should have error message on screen. Remove the power and insert the hard drive. Connect the power supply and attempt to boot.
That sequence should show the issue at the point that there is no display that is where the issue is.
Dec 13, 2013 | Dell Computers & Internet
Unable to POST MB
Try first resetting your BIOS configuration to bring it to its default settings and that should do the trick....
Hope that helps.........
Jul 06, 2008 | Intel Motherboard
When turn shows logo turns off
That sequence should show the issue at the point that there is no display that is where the issue is,
Dec 13, 2013 | Dell Inspiron Computers & Internet
Samsung N102SP doesn't boot
Sounds like a Ram or processor failure. Any beeps?
Take the battery out and pull the power. Wait 2 min and put the power back in and try to boot. That is a start.
Nov 16, 2013 | Samsung NP-N102SP 25.7 cm 10.1inch LED...
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Comp wont start up
The hard disk may have died. Check the BIOS and check the hard disk setting, if it appears OK then boot up with a DOS floppy startup boot disk, and select boot up without CD-ROM support, then type fdisk, answer Y to large disk support, select 4 to Display partition information.
If you see all your disk partition the most likely your hard disk is OK.
Most likely you operating system is damaged/corrupted and you will need to reinstall your operating system and drivers for all your devices.
Nov 28, 2008 | Powmax 400 Watt ATX Switching Power Supply...
ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard boot up
ensure that all connections to the mobo are seated correctly,it is sometimes worthwhile to remove, then reinsert ,ram ,cpu & fan , video card if applicable ,ensure cpu fan is working, that the mobo is not shorting out to the case, ( a loose ***** can do that) also check the power supply for any slight burning smell.
try booting from a floppy or cd with a memory checking program such as memcheck 1.70 or later,
last resort update bios but only when all else fails as this my render the board inoprable ,well it is already so nothing lost .
good luck
Terry
Mar 09, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
Boot up problem
It is possibly the RAM it may have ceased. Look at it underneath held in by two screws. Take it out and examine it then put it back. The motherboard seems ok because you said the lights are lighting up. Sometimes the ram can stop even the bios and nothing can boot up.
Oct 03, 2007 | Compaq Evo Notebook N115
Itz a P2509
try to disable your eithernet card in bios and see if you still get the error.
Mar 30, 2007 | Toshiba Satellite P25-S507 Notebook
Gigabyte 8I845PE-RZ (GA-8I845PE-RZ) Motherboard Logo
89 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
