Question about Pool & Spa
LP flashes when it is turned on
When we turn on the heat pump LP flashes and we cannot get it to work.
  • 93 Answers
THIS IS A LOW PRESSURE CODE PROBABLY LOW PRESSURE SWITCH THE ONLY OTHER TIME THIS COMES ON IF ITS TOO COLD OUT SIDE
Posted on Jun 20, 2009
Why is my Landman smoker that is not heating? Temp,time and everything on screen seems to be ok and heating light is on still not heating, why?
First, turn off the gas on the smoker, then the LP tank. Wait a few minutes. Turn on the gas at the tank, just a quarter turn. Wait 15 to 30 seconds, turn on the smoker and light it.
It that doesn't work, turn everything off and try again. If it doesn't work again then turn it all off and check the venturi, (that is where the gas mixes with air and is located just before the gas flow enters the burner) for spider webs. Just run a pipe cleaner through it.
You might also check your LP tank on a different appliance (like a grill) to see if it is working.
Nov 04, 2014 | Grilling
Turned on my Heat Pump, kicked on for a few minutes, now it won't kick on and code said L5, now says LP. Left it alone all night, still says LP???
HOPEFULLY ITS STILL UNDER WARRANTY.
CALL HAYWARD OR GO TO HAYWARDPOOLS.COM.
THEY WILL SEND A LOCAL SERVICE REP TO COME ADJUST THE FREON LEVELS (LP).
Dec 27, 2010 | Hayward 116k HeatPro Heat Pump HP3100
Heater has power but flashes code L.P
• The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to protect
against certain conditions that could be detrimental to compressor life. The switch turns the heat
pump off in the event of loss of refrigerant, fan motor failure, evaporator freeze-up, or airflow
blockage. The heat pump will automatically reset the switch after the system pressure rises to the
normal operating pressure. The display will show "LP", if this switch is tripped.
For more info, look at page 7 on this manual:
http://www.hayward-pool.com/pdf/manuals/Manual280.pdf
Either you need to defrost the coils, clean the air-flow chamber, get a new air-flow switch or you are running low on refridgerant.
Dec 09, 2010 | Hayward Pool & Spa
How can I reset a Zebra LP 2844 printer to factory defaults
press the green buton untill flash 4 times, then press untill flash 7 times to calibrate and print sensor profile. turn off and turn on again.
Sep 16, 2010 | Zebra LP 2844 Thermal Printer
Panel reads lp error code
Loss of refrigerant, bad motor for the fan clean the coils and unit as described in the manual. Here is a manual from the Hayward website or here http://www.haywardnet.com/products/manuals/pdfs/Manual122.pdf.
Jun 04, 2010 | Hayward 116k BTU HeatPro Digital Heat Pump...
Zebra prints one page then light turns red.
TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
Aug 19, 2009 | Zebra LP 2844 Thermal Printer
1999 dodge ram 2500 5.9 cummins diesel.won't start.turns over thats it. put in a new intake fuel pump. still won't start.got fuel to the injectors sometimes.
Check the fuel pressure at the filter. Odds are the lift pump, located below the filter, is toast. Continual cranking of the motor with a bad LP wil cause the injector pump to heat up and burn out. Replace the LP and fuel filter. Bleed the system by cracking the inlet to the injector pump and bumping the enigine over so the LP will run. Once you have fuel at the injector pump, crack injectors 1,3,and 4. Crank the motor for no more 6 or 7 seconds at a time until it turns over. Give the pump time to cool for a couple of mintues between cranks. This process is easier with two people, one to crank and the other to watch for fuel and tighten the injectors once it starts. If the injector pump is fried at this point from cranking with no fuel, the motor should idle, but will stumble all over itself when the throttle is applied.
-Brandon
Jan 11, 2009 | 1999 Dodge Ram 2500 4WD
Hi worcester 24ri wiring to y plan on boiler it says connect lp lr to pump and sw connect where over run pump
Dont know what your asking but the R is the hot wire to the thermostat, Y's are for cooling, W's are for your heat and the g is for fans. The Y's and W's turn on pilot relays, which control your AC and heat.
Nov 02, 2008 | Heating & Cooling
Pool & Spa Logo
290 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
