Question about Garden
Mower misses out, runs out of gas quick and backfires
Put a new spark plug in. It misses out after it gets warmed up. Runs out of gas quicker than it used to. And it backfires when it runs out of gas.
    Problem Solver:
  • 11 Answers
Sounds like a timing issue. check to see if the sheer key is damaged under the flywheel.
Posted on May 23, 2009
Runs good cold,runs bad when it warms up
misfire is bad timing
check cam time.
check spark timing.
bad timing causes backfiring..
did you put the spark wires back like you found them or better the correct firing order? if not it backfires.
last is lean backfire.
Jan 07, 2014 | 1995 Toyota Camry
Husqvarna 128ld backfires misses but if you put a ignition checker inline with plug it runs ok
sounds like you have a poor connection from the terminal lead to the plug. When the lead is plugged onto the plug it isn't connecting right and when you put the tester in line then it connects correctly at both ends
Mar 20, 2013 | Husqvarna 28cc Gas Line Trimmer
I have a 2000 intruder 1500lc. starts fine runs on idol. than the idol speeds up and than speeds up more. I changed the gas and put in some sea foam. thought it might be bad gas. it back fires and runs...
hi, first thing to do is identify if all the exhausts are hot when the engine has been running for a minit or two, probably the backfireing you are hearing is at least one of the spark plugs has become contaminated with fuel and as a result the engine is not running properly on that cylinder, the backfire will be the exsess fuel igniteing as the plug becomes warm and then fires, it may also be that the fuel has become contaminated, causing a varnishing effect within the float chamber, thus blocking or restricting the fuel flow through the main jet, the machine would run on primary jet and of course the choke jet, but would fail to respond on throttle opening through the main jet, try drain old fuel from float bowls, hope this helps welcome to the motorcycling world, the more you learn about the machine you ride, the more you will enjoy rideing it, paul edwards
Oct 29, 2011 | 2000 Suzuki VL 1500 Intruder LC
I bought a Husqvarna YTH2348 this past summer (may 2010). It ran great until this fall when I got some bad gas. One spark plug fouled out so I installed new ones. I ran it for a while then checked the...
I would start by switching plugs. Then does the wet warm one get hot and does the hot one now stay only warm. If the same plug stays wet, replace it.
If the same cylinder is not firing, check the wiring to the plug. Check the coil wiring and coil for spark to that cylinder.
Nov 30, 2010 | Husqvarna Garden
2002 Big Bear 400. Dies after a few seconds upon startup
sounds to me the valves are not properly adjusted,..like their to tight,...i had run into this in a japanese car once,...check it out and let me know,.....cracklin joe
Jan 10, 2010 | 2002 Yamaha SR 400
Mower runs for about 20 minutes cuts off. Acks
Make sure that the gas cap is allowing air to enter through the small hole. If not, a vacuum will build up and the engine can't get gas. You could try running it with the gas cap on loosely. If that doesn't fix it, the next time it stalls quickly remove the spark plug and see if it is wet. If it is, you will know it's an electrical problem.
Aug 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
Mar 21, 2009 | THQ The Lawnmower Man
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
