Question about Car Audio & Video
The factory radio quit working on 1996 dodge neon
Factory radio just quit working
    Problem Solver:
  • 10 Answers
Try checking the fuse that goes to your radio. you should be able to find the specific fuse in your owners manual.
Posted on May 22, 2009
When I went to change radios, I unplugged the factory radio and my interior lights went out, the power dorr locks quit working, and the headlights quit working with the key off. What did I short out?
check all the fuses in your fuse relay box in your engine bay for a blown fuse also check inside the car sometimes theres another fuse box stashed there.
Oct 09, 2012 | 1996 Dodge Caravan
I need a wiring diagramfor the stereo on a 2001 dodge neon
Sorry to say there isnt one available (if its the factory stereo)...the only diagrams available would be for the wiring in the up to the connector at the back of the radio
Jan 12, 2010 | 2001 Dodge Neon
Speedometer quit but sometimes works. 98 neon
Check the ground wire from the engine to the firewall. It is a flat braided uncoated wire and should be easy to distinguish. Make sure that it is clean and tight.
Oct 08, 2009 | 1998 Dodge Neon
2001 dodge neon radio
Also had no radio but flashing bass/treble indicator lights. As suggested by another post, I disconnected neg. batt. cable and pulled the "interior cluster" fuses, re-set them and then reconnected batt. cable. This fixed the radio.
Apr 04, 2009 | 2001 Dodge Neon
Daylight running module loction
remove the radio from the vehicle..with a trouble light,you should be able to see drl module just below opening..
Mar 24, 2009 | 1996 Dodge Neon
1996 dodge dakota radio and clock don't work but the fuse is good
bad radio i have seen it before have radio or change radio might chrck before you change and be sure the wires are pluged in good
Feb 09, 2009 | 1996 Dodge Dakota
Dodge neon shuts off after i accelearate
a loose belt will not cause the engine to shut off. a loose belt will squeel. it almost sounds like the AC compressor might of locked up and it causing your neon to shut off. if your neon doesnt have ac or the ac is working properly then its something else.
Dec 10, 2008 | 1996 Dodge Neon
Find the pcv valve on a dodge neon 1996
When facing the engine compartment, the pcv valve will be located on the right end of the valve cover. It threads into the cover and will have a rubber hose attached also.
Any further problems, give me a shout.
Nov 19, 2008 | 1996 Dodge Neon
Dodge radio
If you already checked the fuse, you need to check for power to the back of the radio. If power is present there you will need a new radio. Factory radios are expensive, the best bet is to get an aftermarket radio and install it.
Aug 26, 2008 | 2001 Dodge Neon
Tire size
Yes, they will fit just fine.
Aug 15, 2008 | 1996 Dodge Neon
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
