Question about Coby DVD-206
Spindle makes sounds and seems to grind and unable to read discs
All of a sudden, I hear noises as it is trying to spin but instead kind of grinds for a couple of minutes and then says wrong disc and that is even when I put in a new dvd movie.
  • 4 Answers
I did notice inthese models there is a ribbon and for some reason the ribbon will hit the dvd making a noise..push it down it will scrach your dvd
Posted on Feb 24, 2008
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle. Seems like something is stuck in the grinder.
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Breville BES860XL
Horrible grinding/buzzing noise when spinning game discs and does't read them 50% of the time, but plays dvd movies fine with no buzzing/grinding noise no red lights at any time
It the cd drive hub or the spindle motor pad is dirty.
It isn't clamping the disk firmly so when the drive
speeds up or stops abruptly the disc continues
to spin , it shouldn't cause surface damage to
the cd but it sounds like hell .
If you disassemble the xbox and the cd rom
drive ,clean the the hub and spindle motors pad
this should remedy the noise problem.
Also there is the possibility that
the hub magnet came loose this
would decress the clamping force
of the hub, than you would need to
snap the round magnet in the Hub
back in to place . if get there
let me know and ill explain further
if you have any questions just comment and ill respond
Rob
Nov 10, 2009 | Microsoft Xbox 360 Console
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Disc Grinding, Not Motor or Magnet Thing
I think the only option for you is buy a replacement drive off ebay (you want the same model doesnt matter about the FW version) swap the PCB of the drives over so the new one has your old PCB. The same thing happened to me but when I lubed the spindle the grinding noise went away for a week at a time, so I got fed up of constantly lubing it and bought a new one off ebay and swapped the PCB worked brilliant ever since. Hope this helps.
Paul
Apr 25, 2009 | Microsoft Xbox 360 Console
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
360 grinding noise and unplayable disc
Crack open the DVD case and see whats going on and try fixing it yourself. OR Buy a new drive off of eBay and transfer the firmware key over from the old drive too the new one.
Sep 20, 2007 | Microsoft Xbox 360 Console
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Coby DVD-206 Logo
678 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
