Question about Dryers
Wire hookup I have a Whirlpool High Capacity Electric Dryer. I am replacing the heat element and thermostats. During disassemble I failed to label wires. Each part just has two wires but I do not know which one goes to which hookup.
    President:
  • 1,136 Answers
Hi, if you are talking about thewire on element and thermal stat, the element terminals are usually wider then the thermal stat. Does this help? Please let me know. I cam try and get a wiring diagram with a model #.
Vic
Posted on May 23, 2009
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
How to change heating element for accudry
ear cover has to come off. Make sure the heating element is the culprit. Do a Continuity test across the Connector. If the Thermostat fails, you will not get heat either
Aug 09, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No heat in dryer
Most likely, is a broken heating element. 2nd most likely is a thermostat switch that has failed. 3rd most likely is a burnt wire.
If you'd care to fix this yourself,
You will be needing to find a testing instrument to see what is wrong. That would be like a volt/ohm meter or a multi-tester.
First, see if you are getting current to the dryer.
Open the back of the dryer and fine the electric hookup.
You should be getting 110 volts to each side of the 3 wire hookup. The center screw/nut is a ground.
If you have a 4 wire dryer, the extra green wire is also a ground, and should be hooked off to the side.
If you have 110 volts to each of the two sides, then you would remove the back of the dryer, to find the wires for the heating element and all the thermostat switches.
If you have 110 to only one of the sides, check the plug on the wall or floor, and the circuit breaker in the hall or garage or wherever.
Next, you would be removing the plug of the dryer, and check the heating element and the thermostat switches with your resistance setting on the meter.
Unplug each of the items you are testing one at a time.
One of them will show "no current is getting through".
That is you defective part.
Be blessed.
Feb 07, 2013 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Wirer hook up for heat element and thermostats
For these two items ther is no order for the connections. you can just hook them back up.
David
May 22, 2009 | Dryers
Dryers Logo
100 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
