Question about Ryobi Garden
RUNS AND STALL WHEN YOU GIVE IT GAS
I replaced the fuel lines on my ryobi 775r and it runs but when you give it gas it stalls.i was thinking i need to adjust the carberator
    Problem Solver:
  • 11 Answers
You are right on. try richer mixture.
Posted on May 23, 2009
Stalls after start up, Stalls when braking, then runs fine after a few minutes
Check the ECU engine temperature sensor. If it thinks the engine is hot, it will struggle to run when cold.
Mar 06, 2014 | Volkswagen Beetle Cars & Trucks
Starts then stall
I would check the fuel filter- sounds like it could be clogged and restricting your gas flow
Aug 14, 2012 | 2000 Mitsubishi Mirage
MY RYOBI 31CC 775R WEEDEATER WON'T START I REPLACED THE SPARK PLUG AND STILL NOTHING I DON'T THINK ITS GETTING GAS HOW DO I FIX OR REPLACE GAS LINES.
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Jul 24, 2009 | Garden
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
Ryobi 775r won't start. I replaced the spark plug but still no go. I have never replaced the fuel line didn't know that was necessary
make sure you have fresh gas miture first, then put spark plug on housing as you pull it over (with the switch on) watch for spark if its there then its a gas problem. old stinky gas is usually what happens when it sits for months. carb may need to be rebuilt if it still won't start. also check exhaust screen to make sure its not plugged.
Jul 16, 2009 | Ryobi Garden
I have a RYOBI that runs only on very HIGH RPM and will stall if I release gas trigger.
sounds like you have contaminants if carberator, clean out gas tank flush with break cleaner sidconnect fuel lines and spray cleaner through lines let dry refill with gas and retry if still happens carb needs to be rebuilt or cheaper just buy new carb for $50
Jul 06, 2009 | Garden
Camry shudders and quivers when idle, sometimes dies.
Have you had your fuel filter changed? If it is clogged it will take more pressure to operate properly so when you give it gas and it runs better might be an indication it needs to be changed. If you are getting too much gas might be flooding and the computer needs to be checked. But when you said it runs better when you give it gas I would think fuel filter.
Jan 15, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Garden Logo
776 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
