Question about Motorola Mobility RAZR V3
USB connectivity of motorazr v3
...i dont have a usb tool on my connectivity... i only have bluetooth and sync...
what should i do?? pls e-mail me at private_jb08@yahoo.com.ph
thanks a lot!!!
  • 490 Answers
Seee budy what u should do is selct the option of sync after that it will ask for the connectivity medum selct cable and than plug ur cable and try otherwise install the software of Motoral Phone tools. it wikll help u doing it.
Posted on Oct 20, 2007
Motorazr v3
If you have a USB cable you may be able to transfer them just by hooking up the phone. The other option is to get Motorola Phone Tools which should give you the capability to transfer them via USB.
Mark
Motorola Support
Aug 04, 2014 | Motorola Mobility RAZR V3
Dont know how to connect my phone to computer so i can load pics from it? im using usb cable,mob is motorola razr pc is xp?
The should be some Sync software that you can get from motorola. You could also, take the memory chip out of the phone, and plug that nito a card reader, and transfer the music that way.
Oct 07, 2009 | Motorola Mobility RAZR V3
Drivers for phone
www.motorola.com under support for your phone would have the driver and software, thanks and please rate my solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 19, 2009 | Motorola Mobility OEM Bluetooth USB PC...
How do i download songs on to my motorola razr v3m
there are mainly 2 ways to download/transfersongs to your Moto V3 - USB cable & Bluetooth
(though you can also download from internet at the cost of airtime).
USB Cable:
- download and install this usb driver - http://direct.motorola.com/hellomoto/Common/Drivers%20and%20Plug%20ins/USB_Driver_32.zip
- connect the Motorola to the computer through USB cable.
Now you can copy/transfer songs from your computer.
Bluetooth:
Using Bluetooth you can transfer songs from any other Bluetooth device(other Mobile or computer which has Bluetooth)
- Switch On your V3's Bluetooth. Press Menu -> Setting & Tools -> Connections -> Bluetooth -> Setup -> Power -On
- Make your V3 visible to other device. Press Menu -> Setting & Tools -> Connections -> Bluetooth -> Setup -> Find Me
- Now from any other mobile(having Bluetooth), select any song, go to its options, select either Send/Copy which has option To Bluetooth (it'll prompt to switch On the Bluetooth, answer yes)
- click on Search for Device. this will find your V3 in few seconds.
- after this it may ask to set a password, set a 4 digit password, say 1111
- now your V3 will also ask to confirm the password, keyin 1111
- You can see the progress of your song transfer.
(for next song you'll only have to say Ok on V3, password etc. step only one time)
Jun 02, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Sir, i hav motorazr v3
You need to take the phone to a mobile service center and have them reflash the phone's firmware to correct it.
Jun 01, 2009 | Motorola Mobility RAZR V3
I dropped my razr v3 phone. the screen is unreadable. i got an insurance replacement, but before i send the broken one back, i need to find out how to get my pics and videos off of the phone. i can't see...
you can do this with MOorola Phone tools or a number of other syncing software. Unfortunately Motorola Phone tools is not free. But search the internet and you might find for download. You will also need a MINI USB cable to connect your phone to the computer.
Mar 13, 2009 | Motorola Mobility RAZR V3
Can,t hearthe other person
i found a guy with a similar problem I DONT KNOW if it helps but try this....Download P2kTools: here
Connect your V3 via USB to the computer. You can use the same usb cable that comes with most digital cameras instead of buying the motorola one.
Next:
Click on the green button "Switch To" And click P2K.
Then click connect.
After connecting to your phone go to "Tools" Click on gain.
Click "Get" and the settings should be at 0. You can change them to whatever you want. Max is 8. But i wouldnt go higher than 4. When you are all finished click set. Then Click on restart in p2ktools.
The phone should restart and you should be good to go!.
*This mod should work with most motorola phones. Just remember you can only do this via a usb cable and not bluetooth!
Aug 25, 2008 | Motorola Mobility RAZR V3
Unable to sync
Usually rebooting the phone will cure this, I presume you have switched the phone off, removed the battery and restarted?
make sure in
File--> connection settings
that usb and the port you have assigned to bluetooth is enabled
(all tick boxes checked)
try deleting the device from active sync
File--> Mobile device --> (select your device)
then go to
File --> Delete mobile device
make sure you have copies of any un-synced data as it may be lost but shouldn't.
If I remember rightly (dont have a touch to hand) also delete the link to the pc in the active sync window on the touch
Menu--> options (select the server name) Menu-->Delete
and re create the profile by plugging in the device.
May 26, 2008 | HTC Touch P3450 Smartphone
Phone photo problems
 if  u taking about transfering pictures from  phone to computer then u need MOTOROLA MOBILE PHONE TOOLS SOFTWARE .  if u havnt got that with phone arrange it 4rm market .. install it then try to transfer pictures their is an option .. mutimedia .. u can transfer pictures   through  that .. both 4rm hnadset to Pc OR 4rm PC to handset ..........
Oct 21, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
