Hit test/reset button now won't turn back on???
I hit the test/reset button on my portable ac model HPRD12XC5 Haier brand, and I can't get it to turn back on at all after trying every combo possible...
    President:
  • 3,433 Answers
Test, reset sounds like a GFCI. is the machine draing properly? Sometimes the fan will blow , splash water and cause a ground fault. It wouldn't hurt to check the outlut and the breaker controlling it. Just plug a lamp in and make sure there is power.
Good luck.
Posted on May 22, 2009
  • Ned C Cook
    Ned C Cook May 23, 2009
    Not yet huh? Unplug unit, then press reset again.
WATER IS STREAMING OUT OF THE BOTTOM OF MY HAIER AC HPRD12XC5 VERY LITTLE COMES OUT OF THE DRIAN . I OPENED THE DRAIN AND A COUPLE OF OUNCES CAME OUT. MY CONCERN IS ABOUT THE WATER RUNNING ,
It is quite likely that there is a collection tray or tank for condensation inside the machine. The outlet pipe is quite likely blocked. Disconnect it from the mains (just in case) and gently push a piece of wire or stiff plastic rod (strimmer cord ?) up the pipe.
Jul 18, 2017 | Haier Heating & Cooling
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
Hi I've just purchased a used HPRD12XC5 portable air conditioner. It did not come with Air Intake/Outlet hoses, exhaust adapter or window slider kit. Is there somewhere I can buy these? Thanks -...
Harry. if you purchased it from a brick and mortar store, rather than online. Return it to the store for replacement. Or you can get it from Haier under warranty, with your Proof of Purchase. It's more to it than just the air intake and the exhaust hoses.
You can contact Haier Customer Support at 877-337-3639.
Hope this helped you. Please let me know. Thanks.
Jun 02, 2011 | Haier HPRD12XC5 Portable Air Conditioner
The Model # is HPRD12XC5. A red light went on next to the AC fan
The water pan in the bottom was probably full. Did you try to drain it? First uplug the machine from the outlet. There should be a little knob to unscrew in the lower back of the machine. Once you remove it, pull out the little black stopper and have a very shallow pan ready to collect any water. Once everything is drained, replace the stopper and the knob, plug it back into the outlet, and press the reset button. Turn the unit on and wait a couple of minutes for the compressor to start.
Jul 31, 2010 | Haier HPAC90ER Air Conditioner
Haier AC Won't start
I had the same problem with a different model. I tested the cord, it worked, but still would not turn on. Well, after two days my friend and I decided we would try to replace the battery in the remote---it worked! Try your remote battery.
Jun 01, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Haier 8000 btu thru the wall ac wont come on
try ot unplug for 2 minutes,,, and try again may have fuses inside also
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
Haier hprd12xc5
why don't you try www.247servicecenterinfo.com, they have listing of all HAIER service centers in india.
Jul 07, 2008 | Haier HPRD12XC5 Air Conditioner
Haier portable air conditioner HPRDXC5
I just bought this A/C unit today for $649.99 CAD, and it won't cool the room down...small room and I had it on for 3 hours, and it's still 32°C in here...taking it back to Best Buy tomorrow for a full refund. 'Red light is on' means that the water tank is full, as stated in the manual. Open the rubber plug at the bottom rear of the unit and empty out the water so that the unit can function. If this doesn't help, or there is no water in it, the electronics are probably messed up and you will have to send it for repair or replacement. Good luck...
Jul 06, 2007 | Haier HPRD12XC5 Air Conditioner
Will not start
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3632 Hope that helps! ;)
Jul 27, 2006 | Haier HWF05XC5 Air Conditioner
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
