Question about Asko Washing Machines
Cannot stop cycle once it has been started and temp is too high
We are using an ASKO W6362 washing machine. It has been put on the wrong cycle (temperature is too high at 95c) and has started to fill with water. However, we cannot change any of the temperature settings and also cannot stop the cycle to empty the machine. We have tried switching on and off but the cycle is still set to continue. Can you please help. Thanks,Mike
See manual for reset - HOLD stop-button for more then 5 seconds, thats solves the problem :-)
Posted on Feb 20, 2011
Why is it not cleaning dishes?
Contact one of the Asko authorised repairers in your area and they will be able to tell you the likely cause provided the water in your machine is heating up to the correct temperature and not trying to wash luke warm and without the powder dissolving properly.
Set the machine for a hot wash and stop it and open the door mid wash cycle and check how hot the water is. It should be extremely hot and you should get a mass of steam rushing out when you open the door.
Jan 10, 2016 | Asko 24 in. D3121XL Free-standing...
What would cause a nasty metal nashing sound when machine goes from medium spin to high speed spin during spin cycle?
Hi dear,
As I know it happens to other Asko washer models as well. From 800 rpm going up to 12-14 or 1600 rpm. That sounds happens due to vibration generated from motor. I do not thing you can do much about it unless changing motor,which is costly remedy. Thanks.
Jan 09, 2016 | Asko Washing Machines
Asko washer W6324. Ran two loads with no problems. These used the SANI setting (wish I could control the water temp by temp settings and not fabric descriptions). New load of delicates. I set it to woolen...
Try to press the start/stop button for at least 3 seconds. This should reset the started cycle, and you can make a new choice. If this dont help, it could be a faulty control board
Sep 29, 2013 | Asko Washing Machines
Am i able to stop a wash cycle once started?
YES YOU CAN STOP IT BUT IT CN GIVE YOU PROBLEM LATTER.
Jan 21, 2011 | Asko W6021 Front Load Washer
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
I have an Asko W6221. I've just hooked it up and everything seems work work fine except for the temperature dial. It won't turn. It's stuck on the lowest setting. What am I doing wrong?
Hi, welcome to FixYa. If you look directly under the dial, below the rim of the front panel, there should be a lock button. Asko has this safety built in to prevent temp. Change after starting a wash. It is likely in the lock position. This is so once you set the temp. It won't accidently get changed during the cycle. Push it in and turn to lock it, turn and release should "unlock" it. You can also leave it locked by simply pushing it in long enough to turn the temp dial. Hope that helps, let me know how you do or if my explaination isn't clear. Thanks for choosing FixYa, please take a second to rate this solution. Good luck. macmarkus :)
Aug 21, 2010 | Asko W6221 Front Load Washer
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
1. Power it on
6. Power it off and on, again
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
Washing Machines Logo
199 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
