My printer had a paper jam then flaged up check printer 6000 i tried searching on the net and downloaded reg cure as your web site stated but still no joy still showing check printer 6000
if you could help me id be very greatful
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board.
Tips to fix this error code on your Canon printer:
? Turn off your Canon printer for some time, wait for at least 10 minutes and then restart your printer by turning it on
? Check whether the paper tray is set correctly or not. If any foreign substance is obstructing the path of printing, you should remove that object
? Verify whether any tiny object or simply a torn piece of paper is present in your Canon printer. If so, remove it gently to experience smooth printing
? Try to clean other components of your printer machine which includes the print head or the encoder strip.
If you get stuck then do visit us: canon printer error code 6000
Toll-Free No: +1-888-633-7151
Something is in the way of the carriage unit inside printer. Check inside using a flashligh. See my experience in the video:
