Question about Maytag PAV2300 Top Load Washer
Maytag top load washer starts to fill then stops
I have a Maytag Model mavt546eww that begins to fill, gets about 1 inch of water in it then stops. The lights on the rotary dial all start to flash and continue to flash about once every minute.
zeusfaber
  • 247 Answers
SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Posted on Feb 06, 2007
Buffalo12980
  • 625 Answers
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Posted on Sep 02, 2007
dididsaythat
  • 291 Answers
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
  • 409 Answers
SOURCE: Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Posted on Sep 26, 2008
appldoctom
  • 311 Answers
SOURCE: Hotpoint washer fills begins to agitate then refills continously.
yes sounds like you have a siphon problm.thats a your drain hose .you can not seal it with tape.it must have some air and be higher than the washer tub
Posted on Dec 31, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
I have a Maytag A712 top load washer that filled with water and then stopped working. It will not agitate or anything. Also, how do I get the water to drain?
I drain water from stuck machine by filling an appropriately long piece of garden hose with water and holding thumbs on both ends. then i plunge one end deeply into the tub and have the other end below the first end when i let my thumbs loose. This machine has a water pump that will begin to lose a shiny steel retainer that digs into its housing and stops the belt.
Nov 18, 2009 | Maytag HAV3460AWW Top Load Washer
Water overlows from my Maytag Model LAT7304 as it
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
WATER DRAINING
Oct 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Maytag Top loading Washer, fills but won't stop filling and then overflows and will not start the cycle
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
Mar 06, 2009 | Maytag PAV2300 Top Load Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
120 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
