Question about Miele DA249 Kitchen Hood
The plastic clip that secures the buttons is broken
Wher can I source replacement parts
  • 10,865 Answers
Hello.
You can order parts directly: Miele 800-843-7231
Posted on May 27, 2009
  • Joe Hogan May 27, 2009
    Let me know how you make out as I have additional sources if necessary.
I need a replacement play/open button where can I source this please?
search for p/n: 9ka2g297a there are many online parts stores that carry it
May 13, 2014 | Denon DCM-260 5-Disc CD Changer
Tip
Replace Turn Signal Bulb
If you look straight up inside the bumper you will see the plug that holds the bulb just twist and it will come out.
  1. Open the hood and remove the plastic clips that hold the front plastic splash guard in place. This is done by pushing on the center of the plastic buttons to depress them slightly. The button (clip) can then be removed. For the buttons (clips) with the philips head center, lift the philips head center until you hear a click and then remove the whole clip.
  2. Remove the plastic splash guard.
  3. Remove the three 10mm bolts that hold the lens assembly to the fender.
  4. On the fender side of the lamp assembly there is a plastic clip that is inserted in a small flange which is part of the fender. Use a flat screwdriver to put pressure on the back of the post that protrudes through this clip. This post, that is part of the lamp assembly, helps to hold the assemble in the correct position. Once that post is free of the clip the lens assembly can easily be removed.
  5. Un-clip the wires to the main headlights and the the parking/turn signal lamp and remove the lens assembly from the vehicle.
  6. In the case of a fast blinking turn signal, remove the turn signal bulb, test to be sure it is good, and clean the contacts of the blub, bulb holder, and the printed circuit strip on the lamp assembly.
  7. Reassemble everything and test.
  8. Replace the lamp assemble in the fender and secure the splash guard with the clips.
  9. This should be about a 1/2 hour job.
on Mar 17, 2010 | Lexus ES 300 Cars & Trucks
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
Dell 3200MP DLP Projector: displays OK, but with vibrations soon as power button is pressed ON. found cause; rotating see thru thin plastic disk has a quarter of the disk broken off, thereby causing...
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
Jul 04, 2011 | Dell 3200MP Multimedia Projector
Washer will not spin or agitate. found a round rubber piece on floor under washer with six plastic teeth like parts that appear to be broken off.
The motor coupler is broken and the black round rubber piece you found under the washer is the rubber grommet that connects the coupler parts. The six plastic teeth are the coupler prongs, 3 for each coupler part. Replace the motor coupler.
Disconnect power and release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up and set the cabinet aside.
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Disconnect the motor harness then remove the screw securing the bottom clip holding the motor and remove the clip. Hold the motor from the bottom while loosening the screw securing the top clip holding the motor. Remove the clip then pull the motor out of the washer.
Remove the broken coupler parts from the transmission and the motor shaft then tap the new coupler parts in place or until the splines are even with the edge of the coupler.
Remove the motor mounting plate to remove the coupler part in the transmission side more easily.
Once the coupler parts are properly installed, put the rubber grommet into the coupler in the motor then line up the remaining slots on the grommet with the coupler prongs in the transmission and put them together.
Secure the motor with the clips and the clips with the screws then reconnect the motor wiring harness to the motor terminals and reinstall the pump in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Oct 12, 2010 | Washing Machines
I have a 2004 ford ranger fx4 4.0l. i am trying to replace the fuel filter but on of the clips that holds the line to the filter is broken. the line is still secured to the filter but i need to be able...
clean the quick disconnects with brake or choke cleen. there should be a white or green plastic button clip on the disconnect u have to squeeze the green or white rectangle button in to get it to release, the other style has a door u flip open with a small screw driver the push the the plastic catch out the back side of the quick disonnect. (they should call them quick dont disconnect ha ha )
Mar 21, 2010 | 2004 Ford Ranger
Broken front release fascia button. How do I fix it?
only thing i can think of is contact alpine and get a replacement part of find the broken clip and try to glue it stereo parts are hard to fix because the componenent are plastic usaully .
Dec 30, 2008 | Alpine CDA-9851 CD Player
Miele DA249 Kitchen Hood Logo
137 people viewed this question
Top Miele Kitchen Ranges Experts
Jim Thurston
Are you a Miele Kitchen Range Expert? Answer questions, earn points and help others
