Question about Nikon D70s Digital Camera
Pictures taken all come out black
Nikon D70 Camera was working fine one day. Then the next day all I get are black images. Shutter sounds like it is working fine, everything functions okay mechanically, however when viewing in the LCD it comes out black. (yes, the lens cap is off). Downloaded shots I took like this, and they are coming out black on the file. I tried switching lenses and cards. Still the same. Fresh battery and all. The LCD still shows other shots on the card fine, and I'm able to scroll okay through the menu commands. Any ideas?
    President:
  • 1,223 Answers
CCD FAILURE!
Call NIKON for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
Posted on May 23, 2009
Nikon cameras
If you get a black image this is usually caused by a failure of the image sensor or the image compression board
Apr 04, 2013 | Nikon D3100 Digital Camera
My nikon coolpix s70 camera has a black screen but you can still see playback pics opiton button u just can't see take pics anymore it will flash when u take a pic but its still black please help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 19, 2011 | Nikon Cameras
The screen unexpectedly went blank and black....apart from camera info symbols..all pictures taken now are black..... pictures taken before can be seen on screen,....lens moves in and out ok
Jul 04, 2011 | Nikon COOLPIX S220 Digital Camera
My Nikon N50's LCD panel does not work. Everything else works fine; theflash, shutter everything. Help Me Please?
Possible failure of the display unit of the camera is the picture taken is sowing good image after downloading on the PC.
If so the panel must be taken out and checked for voltage on the pad, the flexible strip that connects the display also can be faulty.
You will need to have some experience to open and probe into the display unit.
Jan 06, 2011 | Nikon Cameras
Black LCD
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Oct 01, 2009 | Canon PowerShot A630 Digital Camera
I have exactly the same problem
Sep 19, 2009 | Canon PowerShot A620 Digital Camera
Black Screen and takes blank pictures
It sounds like a stuck shutter. As the camera is less than a year old, Nikon should fix this for you for free under warranty. Contact them.
For others that experience this with cameras that are out of warranty:
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Nikon Coolpix S210 Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
Nikon D70s Digital Camera Logo
305 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
