I bought compatable tanks for my pixma iP4200 and stuck the chips from the original tanks onto them carefully, making sure I had the right colour chips on the right tanks. One of the buttons on the printer was flashing seven times which suggested that I had all the right chips, but in the wrong places. After contacting the compatables' supplier he told me the chips need to be in exactly the right place because of a "laser" which reads them. I have rechecked and I am sure they are in the same place as on the originals. I have since installed this printer to a new computer and it will not install, now telling me I have two or more yellow cartridges in the machine when I try to perform the print alignment. It will not let me install untill I have done the alignment. Any ideas - it is still flashing up a 7 flash signal.
Comments:
Jun 01, 2008
- Don't believe the Canon hype. Have since found out that I really had put 2 yellow chips int here somehow as replaced chip with one I definately knew was from the same colour(Cyan) and it worked and didn't flash any more. My only problem is that I now have no communication with the printer and have worked out that if you take out and insert any of the cartridges too many times it spoils the surface of the chip (even on the Canon cartridges) and then it won't work any more. If I knew how I managed to "reset the chip" without buying a kit, murgatroid, I would be making a million by now, cos thats what I must have done somewhere along the way, it seems, but thanks for the info anyhow. Would anyone know the best generic machines to buy, as I haven't heard of the term before, and would love to save some pennies on a long term basis. The print quality isn't all that essential as long as I can keep access to photo labs on line.
Thanks for the imputs chaps
Glennigogs
-   Mine is the IP4300 essentially the same kit, I believe. Exactly the same problem. I have previously installed compatible ink cartridges without problems, but this time the printer tells me cartridge not installed properly and refuses to print. I may have to spend money on an OEM replacement tank!!-   freddieloh
Best Solution
posted on Jun 01, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I installed genuine canon replacement cartridges and have the same problem i.e. seven flashes, duplicate yellow cartridge.
Worked fine after install and for a while, then started this ****.
Guys...try to save a few bucks on crappy cartridges...
The chips are not read by lasers. That was a load. There are contacts in the carriage assembly for thses chips.
First, if you put a chip that says empty onto a new cartridge, what do
you get? A new cartridge that still says empty. The chip has to be
reset, if it can be. Some internet sites sell "Kits" for resetting the
chips.
If the reset doesn't work, and just buggers up the chip, you'll get results much like what you are describing.
Also, if the chip is damaged in some way during transfer or resetting,
you'll also get mixed results much like what you are describing.
You get what you pay for. If you want to use crap cartridges or crap
ink, buy a crap generic machine. If you're buying a decent machine like
a Canon, spend the extra couple of bucks for the OEM ink, it's worth it.
My pixma ip 4200 printer in printing poor photos , color dull looks like picture has been exposed to...
(More)
My pixma ip 4200 printer in printing poor photos , color dull looks like picture has been exposed to bright light for a long time, color off greens ok reds terrible. Using windows 7 , new computer with quad core cpu ,4 gigs ram and an excellent graphics card, AMD hd 3870. Installed lastest driver. Stored printer for 6 months but just installed all new ink cartridges. Used to print great pictures with my old system Thank you for any help or ideas you may have
smudges and blurred printing after we cleaned the waste tank, I have done printer head alingment...
(More)
smudges and blurred printing after we cleaned the waste tank, I have done printer head alingment several times but this problem persists
The printer is working with paper (both cassette and top feed) but keeps rejecting cd/dvd's. Orange...
(More)
The printer is working with paper (both cassette and top feed) but keeps rejecting cd/dvd's. Orange light flashing twice.
